Big Quest bout Z06 heads LQ4 & LQ9
whats the difference between the #243 heads and the #317 heads? I read on here that the LQ4 heads and the LQ9 heads are the same so what makes the hp diff between the 2 motors?
The chamber size is different, 243 is I think 66cc the 317 is 72cc. They are supposed to flow very close to each other. The cams are different between the two motors also. I think the LS6 has sodium filled exhaust valves also.
So if i put the 243 heads on it should bump my CR up alittle bit? What is the stock CR on a LQ4?
Yeah i know the ls6 specs not to worried bout it i was told it would drop my tq level if i put that cam in. I was just concerned with the Z06's being the same as the LQ4&9's.
I am assuming another diff between the Z06 heads and LQ's besides the Combustion Chambers is the valve springs.
The LS6 heads come with deifferent valves and springs, the valves are a different length due to different size of the camshaft base cicle. The springs are supposed to be good to about .550" lift.
Bore = 4"
Stroke = 3.622"
Chamber size = 70cc (317) or 64cc (243)
Gasket Thickness = 0.054 (standard GM MLS gasket compressed)
Deck Height = 0 (assume zero - can't measure it unless you pull the heads)
Piston Dome/Dish = 0 (for flat top pistons)
Number of Cylinders = 8
What makes up the difference in horsepower is different compression ratio, intake manifolds, cams/springs, and exhaust flow capability.
Bill
The 2001+ LQ4 & LQ9 both have 317 heads. The CR is different due to the LQ4 having dished pistons and the LQ9 having flat top pistons. The cams are slightly different as well I believe.
LQ4 Stuff:
Cylinder Bore Size 4.00
Piston Stroke Length 3.62
Head Gasket Bore Diameter 4.04
Compressed Head Gasket Thickness .052
Combustion Chamber Volume In CCs 71.06
Piston Dome Volume In CCs Negative For Dished Pistons (Use '-') -8
Piston Deck Clearance Negative If ABOVE Deck (Use '-') -.006
