balancer bolt
Old Mar 2, 2009 | 08:57 PM
WJ MARK's Avatar
Default balancer bolt
Anyone remember what size and length bolt is needed for the crank.??? Need to pull off my balancer and replace the seal on the timing cover. Need to to how long of bolt is needed to catch the threads to pull the balancer back on.
Old Mar 3, 2009 | 04:27 AM
sonoma43's Avatar
the balancer bolt is 103mm long so go with something around 120-130ish mm's
Old Mar 3, 2009 | 06:48 AM
white lightning SS's Avatar
Heat the balancer w/ a propane torch lightly. You should be able to then tap the balancer on enough to get the bolt started.
Old Mar 3, 2009 | 10:52 AM
WJ MARK's Avatar
Yeah we did that and think it might have melted the crank seal, cuz now tis leaking. Just want to pull it on there this time.
Anyone know what thread it is???
Old Mar 3, 2009 | 11:03 AM
charcold-bowtie's Avatar
here you go
M16 x 2.0 pitch x 120mm long
pulled from the ls1howto cam swap tutorial
Old Mar 3, 2009 | 11:54 AM
WJ MARK's Avatar
Thanks!
Old Mar 3, 2009 | 01:41 PM
stock48's Avatar
9 Second Truck Club
Also be sure the timing cover is centered, or the seal will leak. Install the balancer with the cover bolts loose then tighten them after the balancer is on. I have a honed out balancer I use to line up the cover.
Old Mar 5, 2009 | 11:30 PM
nonnieselman's Avatar
Now thats a good idea..
Three6GMC
Nov 5, 2015 10:02 PM
Yohns Kustom Fab
Aug 25, 2015 06:53 AM
bgray
Jul 23, 2015 10:56 AM
