Is this any good?
valve spring tool
I'm thinking about purchasing a valve spring tool, but I don't know what's good and what's crap, is that one any good? It comes with the air hold fitting.
I have a friend that made one out of a metal plate, he cut a hole out for a bolt to tighten into the rocker arm mounting holes and there is a slit on the other end that is just big enough for the valve and locks to fit through. Just tighten it down and it will compress the spring so that you can get the locks out and loosen it back off. It takes a little while but it worked pretty nicely the one time that I have used it and the at least 3 or 4 times that he has.
Originally Posted by tdrumm
I'm a big fan of the Crane valvespring tool, it's designed specifically for LSx engines and does two at a time.
Only tool that I could think of that's better for spring replacement is a magic wand
Same here, that tool is awesome! I've used the More? tool (looks kinda like an aluminum rocker arm with a provision for a 3/8 rachet) and 2 prong compressors (that you crank down by hand), and the Crane tool blows them both away. Almost makes it a pleasure to change valvesprings with that tool. (on older sbc's I've had good luck with the tool that looks like a pry-bar with a U cut into it, but I haven't tried it on a GENIII yet)
The pry bar looking one with the U cut in it is good for breaking bolts in the head, but sucks to change springs with.
The two-at-a-time is nice, and the fact that it's tightened by hex-nut instead of by hand makes it possible to put an air ratchet on it and cut your time way down. You don't need the cylinder pressurizer if you do the TDC method.
I don't think it's a matter of good or not, its a matter of how easy it makes it. I wouldn't get that one personally, it might be a high quality piece but it looks like you have to tighten it down by hand, and it only does one at a time. Plus, it doesn't look like it gives you good access to put your finger over the spring locks when you are compressing the spring. If you can't keep them in place they like to shoot out and disappear.
Crane tool
Crane tool
Originally Posted by Colby 04
so I guess nobody knows if the specific tool I posted is any good?
