Is this any good?
Old May 16, 2006 | 06:25 PM
Colby 04's Avatar
Default Is this any good?
valve spring tool
I'm thinking about purchasing a valve spring tool, but I don't know what's good and what's crap, is that one any good? It comes with the air hold fitting.
Old May 17, 2006 | 06:11 AM
tdrumm's Avatar
I'm a big fan of the Crane valvespring tool, it's designed specifically for LSx engines and does two at a time.
Old May 17, 2006 | 11:20 AM
nightmarechevy's Avatar
I have a friend that made one out of a metal plate, he cut a hole out for a bolt to tighten into the rocker arm mounting holes and there is a slit on the other end that is just big enough for the valve and locks to fit through. Just tighten it down and it will compress the spring so that you can get the locks out and loosen it back off. It takes a little while but it worked pretty nicely the one time that I have used it and the at least 3 or 4 times that he has.
Old May 17, 2006 | 12:10 PM
budhayes3's Avatar
PT's Slowest Truck
Same here, that tool is awesome! I've used the More? tool (looks kinda like an aluminum rocker arm with a provision for a 3/8 rachet) and 2 prong compressors (that you crank down by hand), and the Crane tool blows them both away. Almost makes it a pleasure to change valvesprings with that tool. (on older sbc's I've had good luck with the tool that looks like a pry-bar with a U cut into it, but I haven't tried it on a GENIII yet)
Only tool that I could think of that's better for spring replacement is a magic wand
Old May 17, 2006 | 12:19 PM
white1's Avatar
The pry bar looking one with the U cut in it is good for breaking bolts in the head, but sucks to change springs with.
Old May 17, 2006 | 02:53 PM
tdrumm's Avatar
Or a check book.
Old May 17, 2006 | 03:22 PM
thunder550's Avatar
High on diesel fumes
The two-at-a-time is nice, and the fact that it's tightened by hex-nut instead of by hand makes it possible to put an air ratchet on it and cut your time way down. You don't need the cylinder pressurizer if you do the TDC method.
Old May 17, 2006 | 03:38 PM
Colby 04's Avatar
so I guess nobody knows if the specific tool I posted is any good?
Old May 17, 2006 | 04:08 PM
thunder550's Avatar
I don't think it's a matter of good or not, its a matter of how easy it makes it. I wouldn't get that one personally, it might be a high quality piece but it looks like you have to tighten it down by hand, and it only does one at a time. Plus, it doesn't look like it gives you good access to put your finger over the spring locks when you are compressing the spring. If you can't keep them in place they like to shoot out and disappear.
Crane tool
Old May 17, 2006 | 08:10 PM
budhayes3's Avatar
PT's Slowest Truck
Whoops...I didn't even check your link, I thought you posted up the Crane tool lol. I've used the tool that you posted also...it works, but it's time consuming and a bit of a pain in the butt to use. When I did my springs the first time around, I used that tool for the springs closest to the firewall since the More tool couldn't get a good angle and wouldn't push the spring down straight. I think I kinda banged up one of the valve stems with that tool also...I noticed some nicks on the stem of the valve closest to the firewall on the pass side the second time I did my springs, which is when I used the Crane tool. I'd definitely recommend the Crane tool over that one any day
