Is this any good?
Old May 17, 2006 | 08:44 PM
speedy02's Avatar
Originally Posted by thunder550
The two-at-a-time is nice, and the fact that it's tightened by hex-nut instead of by hand makes it possible to put an air ratchet on it and cut your time way down. You don't need the cylinder pressurizer if you do the TDC method.
I used the same tool but, I used a leak down tester to keep the valves up..
Old May 17, 2006 | 10:18 PM
Colby 04's Avatar
The cam and springs will be done on the engine stand before the 6.0 goes in...so I'm not worried about clearance on the rear cylinders. What does that crane tool run?
Old May 18, 2006 | 06:08 AM
tdrumm's Avatar
The crane tool is expensive - like $100, but it is such a breeze to swap springs with it. Fast too.
Old May 18, 2006 | 12:41 PM
sliderbkt's Avatar
Colby, I use a tool like the one you posted. It works fine, but is more time comsuming than the others. But you can get them much cheaper. I think mine was like $15. Plus, you can usually get a loaner from Auto Zone etc.
Jakejack
Jan 8, 2024 10:44 PM
Dan Neumann
11
Aug 7, 2022 09:06 AM
Raggedz71
Jul 29, 2016 10:20 AM
DrX
Aug 19, 2015 04:45 PM
ntxf
Aug 10, 2015 10:12 PM
