aluminum VS Iron
Old Feb 13, 2010 | 10:22 AM
53RUSSELL's Avatar
Default aluminum VS Iron
I building a forgen LS1 and i have 873 iron heads witch flow the same as 317 heads. My concern is putting iron heads on aluminum block and the motor being boosted. I know the that iron head don't dissipate heat as fast as aluminum heads. So what do you guys thunk?
Casting Number 873
Head: 1999-2000 LQ4 6.0 Liter Truck
Material: ***Cast Iron***
Part Number:
12561873
Combustion Chamber Volume: 71.06cc
Compression Ratio: 9.5:1
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Old Feb 13, 2010 | 10:42 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
I think I'd look for a cheap set of 317's
Old Feb 13, 2010 | 11:41 AM
budhayes3's Avatar
PT's Slowest Truck
+1 used to be able to get good used low mile 317's on ebay for about $250 when they were more abundant, and I'd assume that they're still inexpensive considering how the L92 setup is getting more and more popular.
Old Feb 14, 2010 | 04:14 PM
joeyc125's Avatar
11 Second Truck Club
X3, I would think that the hotter combustion chamber would limit you on timing, and in an FI application, timing is big power to lose.
Old Feb 14, 2010 | 04:32 PM
Mangled03gmc's Avatar
Baltimore Whore
Yah all the above..
Go5.3tt06
25
Sep 4, 2016 10:25 AM
GM1697
Oct 20, 2015 12:12 PM
old motorhead
Sep 29, 2015 08:22 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
