advice on valve train for 6.0
Old May 19, 2016 | 12:31 PM
  #21
Taylor Bickett's Avatar
yep almost the exact same i think. TSP's are just a little cheaper.
Old May 23, 2016 | 01:15 PM
  #22
legerwn's Avatar
Still working on my list of parts for the 6.0
I appreciate all the help,
Parts list;
Lunati 55003LUN
Springs, Retainers, Seals
Lifters (still trying to figure out if I can use New GM lifters)
gasket set
Head Bolts
Rocker Trunion BRG upgrade
High volume oil pump
Going to try the stock injectors and see what happens, if needed I'll get larger ones (I'll watch the fuel trims on this).
Due to the valve cover issues with swapping to the 806 heads for now I'm going to stick to the 317's.
Neal
Old May 23, 2016 | 03:21 PM
  #23
Wolftrk99's Avatar
Yes the gm lifters will be fine.... Gmpp has the ls7 lifters in a package of 16.... Ihave a set of melling lifters that next to the gm ones you cant tell them apart, put those next to the comp cams lifters and again you cant tell a difference in any of them....
Old May 23, 2016 | 05:07 PM
  #24
Beatdown Z's Avatar
Laid Back
Is this truck already running?
Old May 24, 2016 | 09:45 AM
  #25
legerwn's Avatar
It was, I pulled the 6.0 out to do some work to it (cam and stuff) and put the 4.8 back in for now.
The 6.0 was in the truck for around a 9 months or so
Neal
Old May 24, 2016 | 08:31 PM
  #26
Wolftrk99's Avatar
Was the 6.0 making noise??
Old May 25, 2016 | 08:28 AM
  #27
legerwn's Avatar
It did have a slight lifter noise at start up
11MPG
May 18, 2016 06:45 AM
Ryan Roepe
May 11, 2016 02:49 PM
Joevc
May 7, 2016 12:16 PM
Mean Green z28
May 4, 2016 08:24 AM
~VH~
Apr 26, 2016 08:27 PM
