advice on valve train for 6.0
Old May 16, 2016 | 12:04 PM
legerwn's Avatar
Default advice on valve train for 6.0
Picked up a Lunati 55003 LUN cam and need to see what I need for a valve train.
Thought I would stop here first to get input on it,
Advertised Duration (Int/Exh): 282/287
Duration @ .050 (Int/Exh): 218/221
Gross Valve Lift (Int/Exh): .526/.534
LSA/ICL: 116/112
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 2000-500
will the GM valve train work with this cam?
Thanks for any help
Neal
Old May 16, 2016 | 12:14 PM
FFDP's Avatar
Some new lifters and figure out what size pushrods you need and you are fine.
Stock rockers will be okay.
Old May 16, 2016 | 02:31 PM
03sierraslt's Avatar
Valve Springs also
Old May 16, 2016 | 03:04 PM
Wolftrk99's Avatar
Ls6 springs shoukd be fine with that cam, no??
Old May 16, 2016 | 04:53 PM
legerwn's Avatar
Thanks for the input,
ended up going talk with the guy I got the cam from and he handed me the valve springs, retainers, keepers and the seals that go with the cam, so that's covered for now.
He also handed me a set of bare heads, they have 806 cast into them and I have a set of 817's, so now I have to decide which ones will be the best for my build and bring them to a buddy of mine that has volunteered to do some porting for me.
He did a set for another buddy with the exact same cam in a 6.0 that is in a Maverick that turned out over 400 HP at the wheels with some tuning.
Neal
Old May 16, 2016 | 06:31 PM
Gadgetized's Avatar
A trunion upgrade is cheap insurance while you are doing the work.
Old May 17, 2016 | 07:02 AM
zero2sixT's Avatar
I'd run the 806s. They have 66cc chambers. Get a little bump in scr over the stock 317s.
Can't find anything on a 817. Search shows its a casting for a 400 block.
Old May 17, 2016 | 07:27 AM
legerwn's Avatar
I might have the casting # wrong, thought it was 817 maybe its 317's.
Old May 17, 2016 | 07:36 AM
legerwn's Avatar
They are from a 02 6.0 so it looks like they should be 317's
Old May 17, 2016 | 09:55 AM
zero2sixT's Avatar
are they aluminum?
If they are 317s, I'd run them instead. Mill them down if you want to bump compression
