5.3L LS1 cam swap parts needed
Old May 9, 2016 | 09:53 PM
Ryan Roepe's Avatar
Registered User
Default 5.3L LS1 cam swap parts needed
So I'm doing an LM7 swap in my '93 300zx, and decided to pick up an ls1 cam on the cheap just to get it running (spun a cam bearing). I've gathered that I need 7.4 pushrods, stock rockers, ls2 timing chain/gear/sprocket, and stock lifters, but can't get my head around how to choose springs. I *think* 2002 ls6 yellow springs are the best bet for this setup, but this is my first time doing a cam swap. Any information is much appreciated.
Old May 10, 2016 | 10:14 AM
turboal1's Avatar
Default Springs
Go with a set of Pac 1218 springs, good for .600 lift
Old May 10, 2016 | 11:01 AM
Wolftrk99's Avatar
The ls1 cam is also the lq4/9 so you should actually be ok with stock springs, if you want more just for peace of mind then the ls6 springs would be fine!!
Old May 11, 2016 | 02:49 PM
Ryan Roepe's Avatar
Registered User
Thanks guys I went with some LS6 springs from GM.
regency
Mar 20, 2016 10:41 PM
opsguy34
Mar 17, 2016 05:14 AM
JCunningham
Mar 17, 2016 04:48 AM
09CamdSilvy
Mar 2, 2016 09:47 AM
NHolds
Feb 19, 2016 01:37 PM
