advice on valve train for 6.0
Old May 17, 2016 | 05:30 PM
legerwn's Avatar
Originally Posted by zero2sixT
are they aluminum?
If they are 317s, I'd run them instead. Mill them down if you want to bump compression
They are aluminum
Thanks Neal
Old May 17, 2016 | 05:35 PM
legerwn's Avatar
Originally Posted by Gadgetized
A trunion upgrade is cheap insurance while you are doing the work.
Rocker arm trunions?
Where would I get upgraded trunions?
thanks Neal
Old May 17, 2016 | 05:49 PM
Wolftrk99's Avatar
Google search for comp trunnion upgrade... Or btr trunnion upgrade, or im sure someone will chime in with the name of the bushing style trunnions....
Old May 17, 2016 | 05:50 PM
Wolftrk99's Avatar
Heres a link..... http://m.summitracing.com/parts/cca-...FYEehgodoIkPbw
Old May 17, 2016 | 08:52 PM
legerwn's Avatar
Originally Posted by Wolftrk99
Thanks for the link, I'll take a look see
Neal
Old May 18, 2016 | 12:44 PM
Taylor Bickett's Avatar
https://www.texas-speed.com/p-5213-t...s-engines.aspx
here is a link to the texas speed trunions. These are the ones i used and it took about 20 minutes in a bench vise. super easy and these are a little cheaper than the comp trunions
Old May 18, 2016 | 02:13 PM
legerwn's Avatar
Appreciate it, I'll take a look
Neal
Old May 18, 2016 | 08:32 PM
Wolftrk99's Avatar
Are the texas speed trunnions bearings or bushings??
Old May 19, 2016 | 12:12 PM
they are bearings, little needle bearings but they are held in, not just sitting in there. if somehow the c clip would break and the bearing fell out it wouldnt send the neeldles anywhere.
Old May 19, 2016 | 12:27 PM
Wolftrk99's Avatar
Comps are same basic design i think...
