99-06 5.3 cam suggestions
Old Dec 8, 2017 | 05:33 PM
Apollo_LS's Avatar
Registered User
Question 99-06 5.3 cam suggestions
We know that there are many cams out there for a 5.3 and vary from sizes to lobe seperation.To get to the point im looking for is a cam thats agressive and give big rwhp for a stock 5.3l and 4l60e. With all the reaserch i want to know from you guys what cam you think is best or recomend? I would very appreciate for your replies, thank you in advance
Old Dec 8, 2017 | 05:39 PM
FFDP's Avatar
Something that is in the area of 212/218 with like a 112-114 LSA, with supporting valve springs.
Anything much larger requires an aftermarket stall converter.
Consider buying slightly larger fuel injectors too depending on model of truck you are working with. Non flex fuel 25/lb/hr injectors do not go very far.
Old Dec 8, 2017 | 07:04 PM
10 Second Club
I'll have to agree with FFDP, that's about the most aggressive you'll want - unless you are going to do a loose converter, and all the other supporting mods.
Old Dec 8, 2017 | 09:28 PM
_zebra's Avatar
makes children cry
also, if you ain't planning on adding headers (though highly recommended), you'll want one with a tad more exhaust duration.
Old Dec 9, 2017 | 10:17 AM
Apollo_LS's Avatar
Registered User
What needed if for examp;e i went with a bigger cam? thank for your replies
Old Dec 9, 2017 | 10:29 AM
FFDP's Avatar
Kinda depends on what you pick.
A stall in the 2500-3000 range is a good bet, larger fuel injectors and a tune of course.
Pray the transmission is strong and carry on lol.
Old Dec 9, 2017 | 03:08 PM
turboal1's Avatar
Default cam
I used a 210/224 114LSA, with headers in my 5.3
stock 4L60, no conv. factory inj. but it was a VVT cam.
prob could of used a conv.
Old Dec 13, 2017 | 04:25 PM
BlackPanther6.0's Avatar
ive had very good luck with the 212/218 grind, ive had the low lift version from comp on my 5.3 with supporting mods, and now i have it on my 6.0 with ported heads, its the BTR stage 2 grind. i wish i would have gone bigger, i guess just to satisfy my wanting of higher hp numbers on the dyno but the truck is a monster now, it took a friends 04 lightning with pulley and programmer. it hauls. i recommend that cam if not wanting to change converter. good power all around.
ig109
Dec 4, 2009 06:10 AM
ranwalk
Nov 9, 2003 10:19 AM
creederado
Jul 5, 2003 09:10 AM
Okie02
Jun 16, 2003 05:27 PM
Texas Terminator
17
Feb 8, 2003 09:44 AM
