6.2 Blower Cam?
Old Jun 22, 2014 | 04:53 AM
Longbow's Avatar
Default 6.2 Blower Cam?
So, I am looking for the next power adder for my truck. I had thought about CAI, 90mm TB, and high flow MAF but it seems that those options would only provide me with a marginal power increase. So I have turned my eyes towards a new cam. Only problem is I am a complete noob when it comes to cams. I am not even sure if I would need new rods, springs, or rockers (although I heard the stock rocker arms are better than aftermarket). Do you guys have any idea about cam specs or what I should replace along with the cam?
PS: I know converters are a popular option but considering this is my DD and my cruise RPM is below 2000, its not an option for me. As for gearing I would love to swap to a lower ratio but being my truck is AWD, I havent found any viable options.
Old Jun 22, 2014 | 07:10 AM
TIM Z's Avatar
11 sec. Truck Mod
Hey bud , welcome to the site .
I have an interest for the project / truck/ mods your doing/ reaserching Lol
Anyway let's see if we can all help ya get where your going or wanting to be.
1. Don't buy a larger/or aftermarket MAF , if your wanting to make good-to great power , you'll want to ditch the MAF anyway for. Custom Speed Density tune to compliment your future mods.
2. A 90mm Throttle body is a great idea .
3. Cam wise you'll want something in the 220-235ish range . Maybe even a hair larger since you already have plenty of low end TQ from the blower., but stall converter will help also .
4. Only new push rods and stiffer valve springs will be required to compliment your cam install . Stock rockers and lifters are fine ( unless you have over 150k on your stock lifters).
5. ,The 6 speed in our trucks is pretty stout when tuned properly , and has a great lower first gear ratio to help get ya moving , so I would wait on gears for a future future mod
6. A 2600 , 2800, or 3000 stall torque converter will compliment your blower nicely , and drive like stock till ya mash it , getting you in your power band quicker .
I reccommend and only use Precision Industries Triple disc vigilante converters , they are tough and reliable and I have beat the **** out of 3 of them with no problems , they drive , race , and tow excellent .
You can also check out Circle D , they have nice units too I've heard .
Then also I'd lower your pulley size and also you'll need to keep in account how much boost/ power your fuel system will support as it may need modded too.
Old Jun 22, 2014 | 11:26 AM
KozzyJr's Avatar
Well said Tim. For a cam you can always get one spec'd out. To fit you needs and wants.
Old Jun 29, 2014 | 02:21 AM
Longbow's Avatar
Thank you again Tim! I have heard that the 90mm TB doesnt do much besides change your throttle resolution. Although, I must admit, I have wondered if it may give me some more airflow at my high end. Have you seen any gains (other than driveability) from a 90mm?
What do you think about aftermarket CAIs for a truck like mine?
You havent had issues with heat generation from the higher stall converters? I have heard two stories, one is that before stall RPM the converter is slipping ie: during cruise. I have also heard that there is a mechanism which will lock up the stall converter to prevent slippage during cruise.
As far as the smaller pulley, I am wary of turning up the boost any more on my all stock engine. I should be running about 8.5lbs at sea level.
Old Jun 29, 2014 | 04:48 AM
gamble686's Avatar
Don't worry about the intake until it becomes a restriction. Cam wise 222/230 LSA115+2 would work amazing. An aftermarket stall in the 2600-3000 range should drive exactly like stock with a good custom tune don't by a good professional tuner. You will want to pulley down as some new mods here will actually appear to reduce boost which really your just building efficiency.
Old Jun 29, 2014 | 08:47 AM
TIM Z's Avatar
11 sec. Truck Mod
My thought is if you have a blower or turbo , why restrict the opening that the engine depends on getting air from ?
My blower inlet is at least 90 and if I recall it may be 4.5" instead of 4" , so 90mm only made sense to me and installed it right off the bat .
Yes you will see gains of a larger intake tube and filter , I Fabbed up a 4.5 pipe that connects a large AFE dry flow diesel filter to my Throttle body with a 4.5"x4" reducing elbow . All I can say is it puts down the beans on the dyno
My trans runs at roughly 150-160* when romping on it , and cooler when cruising unless is like 90ish* outside then it's always around 150-160 ,
So NO heat issues with my stall , your thinking of those big Loose stalls that are like 3600-up , they have to slip a lot more than a tighter well built converter like my Precision Industries , I love this converter .
Don't be afraid to run more boost , 8.5 is nothing on a stock motor and your only cheating yourself . I rock a stock LQ4 long block as do a ton of others and if I could get more boost out of my combo I would !
This is true info right here verified by a well reputable tuner/engine builder.
" The rule of thumb for a stock LS bottom end is roughly 850ish horse power till a rod will bend , yes the rod will bend before a piston breaks on a properly tuned engine , if a piston pops before you bend a rod or at lower power levels it's not tuned right, roughly 20psi is max you want to run on a stock long block but it must be spot on tuning wise, "
This is not gospel but a good indicator of how far you can push a stock engine . Take it for what it's worth
Old Aug 9, 2014 | 05:31 PM
N/ALS1's Avatar
On the statement made about the stock bottom end, are there certain years that can handle that. I thought stock bottoms were only good for 500hp. Good info though.
TXsilverado
Nov 26, 2015 10:54 AM
zo6freak
14
Oct 18, 2015 06:43 PM
rudvirus
Aug 5, 2015 08:05 PM
Matt331
Jul 26, 2015 09:40 PM
