6.0l lq4 help with cam.
Old Nov 1, 2015 | 08:28 PM
1500hdsilverado's Avatar
Post 6.0l lq4 help with cam.
Ok guys I need some help choosing a cam for my 2003 silverado 1500hd Lq4. I'm wanting to run a z06 cam. When I find the cam does it need to be year specific? I plan on running 243 heads and z06 springs that I have. Other mods I have are F.A.S.T RT 102mm intake, Pacesetter longtubes, CAI, and exhaust. Or should I run a different cam? I don't plan on doing a stall. And this is my DD. All opinions welcome. I just want to be able to drop a cam in with out any other problems to fix.Tanks in advance
Old Nov 2, 2015 | 09:18 PM
Bump.
Old Nov 2, 2015 | 09:28 PM
Wolftrk99's Avatar
So long as its 3 bolt from a gen 3 engine you should be fine, do believe the pushrods are different length though as i understand the base circles are smaller on the z06 cam.... I would at least upgrade to ls7 or z06 lifters while youre in there... As well as the valve springs
Old Nov 5, 2015 | 08:15 AM
shootermwc's Avatar
2WD or 4WD? Any nitrous planned? Or is it just a daily driver/play truck?
Old Nov 5, 2015 | 07:37 PM
LARRY01Z28's Avatar
I would put a 212 218 low lift comp cam in it. that would be perfect.
Old Nov 5, 2015 | 07:38 PM
LARRY01Z28's Avatar
or even one of the BTR truck cams. stage one or two
Old Nov 11, 2015 | 04:27 PM
shootermwc's Avatar
That's pretty small unless he is going for max low end torque and and towing power. If he wants some top end nuts and a lopey idle I would be bigger by about 10-12 degrees.
Old Nov 16, 2015 | 03:19 PM
thompson's Avatar
Banned
I agree that if its going to be a heavy truck with a stock converter something in the 212/218 range is going to be pretty ideal. Going much larger than that is going to translate into poor drivability and the truck feeling sluggish down low. If the OP was open to an aftermarket stall converter I would probably recommend something slightly larger, but not by much. At the end of the day if this is a DD for him a big aggressive camshaft and stock torque converter is definitely not the right move for him.
Thanks
Aaron @ Thompson Motorsports
Old Nov 30, 2015 | 06:33 PM
Bdanielshd's Avatar
which cam did you choose?
Old Jan 7, 2016 | 01:24 PM
release2063's Avatar
Tsp 212/218 600 lift 112+2 lsa makes great power in mine
zx3focus
Oct 22, 2015 07:37 PM
JordanH
Oct 16, 2015 12:47 PM
KleanKustoms
Oct 14, 2015 09:50 PM
Silver8ado
22
Oct 13, 2015 06:54 PM
