l96 heads
Old Oct 7, 2015 | 05:16 PM
Silver8ado's Avatar
Default l96 heads
Planned on retaining VVT in my swap but the information on the wiring seems non-existent. If i cant get the wiring down it seems an ls9 cam would be the best budget cam for this 6.0. Thoughts on milling the heads?
Old Oct 7, 2015 | 05:20 PM
Silver8ado's Avatar
Also, thoughts on swapping a set of 243 heads from the old 5.3?
Old Oct 7, 2015 | 09:54 PM
Wolftrk99's Avatar
Old 5.3?? I saw a stock 2010 or 2011 with 243's on it in the last few weeks!!!
Old Oct 8, 2015 | 09:45 AM
Silver8ado's Avatar
Stock on my 2007 lh6 aswell
Old Oct 8, 2015 | 01:57 PM
07NBSChevy's Avatar
243 heads were used up to 2013. Im pretty sure L96 heads have rectangular ports and 243 heads have cathedral ports and wont interchange.
Old Oct 8, 2015 | 02:33 PM
Wolftrk99's Avatar
They will bolt on, but iirc the valves are smaller and combustion chambers bigger on the 243 than the l96, aside from rectangular vs cathedral intake ports..
Old Oct 8, 2015 | 08:30 PM
Silver8ado's Avatar
Ill stick with the l96 heads then.
Any info on the tsp 220/224/228 cams?
For $200 more what would I see for gains
Stock converter so im leaning towards the tsp 220 or tsp 224
Old Oct 9, 2015 | 12:19 AM
It's a down hill mod spiral one leads to another. You can almost pick up as much of the SOTP difference by doing a converter as you can doing a cam swap. Better bet is to do both at the same time cam and a converter. The stock converter is usually pretty doggy out of the hole till you get it wound up. The stock converter is just too tight.
Old Oct 9, 2015 | 08:34 PM
Silver8ado's Avatar
Going to try a TB converter.
Any info on cams or bumping compression?
Looking at an ls9 cam or a tsp 220/tsp 224
Old Oct 10, 2015 | 01:08 PM
Bumpers's Avatar
I just built a l96.. milled 15 of the heads and run a .040 head gasket.. apparently somewhere in the 10.8to1 range
