5.3 performance mods
Old Feb 26, 2012 | 12:23 PM
blake_levesque2's Avatar
Registered User
Default 5.3 performance mods
Look'n to get a lil horsepower out of my stock 5.3. other than the obvoius bolt ons, any advice as to what cam and stall combo would go well???
Old Feb 26, 2012 | 12:50 PM
ak2007r6's Avatar
This link should help you out. Ask each question and you will see lots of info on each
PerformanceTrucks.net Forums - Search Forums
Old Feb 26, 2012 | 01:00 PM
Chevy_King1500's Avatar
whats a lil horsepower? 15-20? 200? 300?
Old Feb 26, 2012 | 01:28 PM
Registered User
i'm think'n 200+. i know cam i'm look'n at right now brings it from a stock 259hp to 341.
Old Feb 26, 2012 | 02:19 PM
jrmchevyman's Avatar
Searching will bring up all you need to know like stated.
Do you have a RCSB or is it extended cab, etc?
Basically if you are looking for a nice cam, do full boltons + the cam and if the cam is bigger than a certain point then a higher stalling converter is highly recommended. Also if you have a heavy truck with big wheels/tires you may or may not need to add new gears in the mix.
Something like a comp 212/218 would work fine with stock converter, and you will feel noticeable gains everywhere. If you go the next step up from that say like a Tsp220 or TR220 again you COULD get away with stock converter, but I HIGHLY recommend getting some type of higher stalling converter, at least a 3000 rpm. 3000-3200 would work pretty good, if you wanted to get the best out of a 220 cam then a 3400-3600 would be optimal, but not everyone wants a converter that size in a daily driver. Many people daily drive a 3400-3600 though, its all personal preference.
Or you could get someone to spec you out a custom cam for your goals and mods.
Old Feb 26, 2012 | 03:18 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
You found a cam that will add 82 hp to your stock setup?
Old Feb 26, 2012 | 04:06 PM
dmelvin's Avatar
Damn.. took me cam, heads, LTs, and efans.
OP - You know that a stock setup the motor has 295HP at the crank, not at the wheels right? Depending on your truck (2wd or 4wd) You're probably looking at closer to 220-240 at the rear wheels.
Getting 200 more ponies out of a 5.3 is going to take boost or nitrous. No way around it. Either one is going to affect your cam, exhaust, and intake selection.
So you need to decide if you want to stay NA or boost it, or gas it. Then we can kinda help show you the way.
Old Feb 26, 2012 | 04:11 PM
ak2007r6's Avatar
Boost!!!!
Old Feb 26, 2012 | 04:48 PM
mcfarlnd's Avatar
Un-Registered User
Search!!!
Old Feb 26, 2012 | 04:59 PM
Nflddog1000's Avatar
200+ is gonna cost ya cam, heads, FI, then theres the tranny $$$$$
