5.3 n/a
Old May 8, 2006 | 11:02 PM
  #61
that sucks
Old May 8, 2006 | 11:04 PM
  #62
TouchOfEvil04's Avatar
How do you know if you have an HO motor???My window sticker said nothing of it being a 5.3L HO?
Old May 9, 2006 | 06:25 AM
  #63
tdrumm's Avatar
Well, the big tip off is the aluminum block. It is engine code L33.
Old May 9, 2006 | 03:49 PM
  #64
BLACKND's Avatar
Extended cab 4x4's are the only trucks that I know of that come with the L33 HO 5.3. My 2006 Z71 has one.
Old May 9, 2006 | 04:28 PM
  #65
stretch104's Avatar
seems like alot of work and then the 5.3 would be a little high strung. i have connections that i could get an ls1 cheap. how hard would it be to swap in an ls1, and still keep all the a/c and power steering.
Old May 9, 2006 | 07:06 PM
  #66
ap2002's Avatar
I think chago's CC 2wd has a L33??
Old May 9, 2006 | 07:22 PM
  #67
white1's Avatar
Easy. Im not 100% sure, but I think the A/C bracket will bolt up fine.
Old May 9, 2006 | 10:05 PM
  #68
im pretty sure its all a direct bolt on...if you can get LS1's cheap could you get lq9's cheap too?? how cheap are you talkin?
Old May 9, 2006 | 10:08 PM
  #69
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
LQ9s are few and far between compared to LS1s. The ratio seriously is about 150:1 for those motors.
Old May 9, 2006 | 10:24 PM
  #70
i see what about the lq4?
