450 Wheel hp lq4 build
Old May 22, 2018 | 12:39 PM
Sierraman02's Avatar
Looks nice does it come with the fan? Could I keep the stock bottom end I would put new head gaskets on how much wheel hp are you thinking?
Old May 22, 2018 | 01:26 PM
Torqstorm's Avatar
Former Vendor
Most guys will upgrade to the fans as an early on mod. We do not provide them, they are just the later factory fans with a relay harness setup from many different retailers in the car industry. Stock bottom end is plenty strong for 8# of boost. We gained over 150 whp on a stock 6.0/ 4l80e 4x4 silverado with 160k miles.
Attached Thumbnails 450 Wheel hp lq4 build-baseline.jpg   450 Wheel hp lq4 build-after-dyno.jpg
Old May 22, 2018 | 01:37 PM
Would it stock hold to 450hp?
Old May 22, 2018 | 01:53 PM
MrHorsepowerLSx's Avatar
11 Second Club
Yes, but a good set of heads/cam/exhaust will help the motor make more power more efficiently and easier with less boost also
Out of curiosity, why are you stuck on the number 450? Do you plan to race the truck any
Old May 22, 2018 | 02:13 PM
Torqstorm's Avatar
Former Vendor
Yes the engine should be fine at 450 whp. Like MrHorsepowerLSx said supportive mods will help free up untapped horsepower by letting the supercharger utilize the airflow better in the engine.
Torqstorm
Old May 22, 2018 | 02:40 PM
Not to stuck on 450 that is my goal I could go with more like 500 I would have long tube headers aftermarket y pipe and dual ehuast all 3” hopping for 450 or more as a daily driver that can beat ricers lol.
Old May 22, 2018 | 03:32 PM
11 Second Club
450 NA is a long shot and the cam needed to get you there will make street manners suffer, easily obtainable with FI tho. FWIW I was in the neighborhood of 410 RWHP NA with an LQ9, and was running low 12’s.
The truck now has over 600rwhp and I still drive it almost every day
Only point I was saying is that anything over 400 to the tire is going to feel like a monster on the street
Old May 22, 2018 | 03:46 PM
I think I will go with a supercharger I could always upgrade after for even more power. Will cam it advetually for the more power will have to do reaserch into cams for superchargers
Old May 22, 2018 | 04:14 PM
11 Second Club
Look into a custom grind cam, companies can help spec you out a cam best suited for your needs.
Old May 22, 2018 | 06:12 PM
Who makes good custom ground cams?
