427 from a 6.0L iron block
Old Jan 16, 2008 | 10:52 PM
03 BLACKOUTSSS's Avatar
Default 427 from a 6.0L iron block
first, isthe thread title even possible?
Is 9.0:1 cr achievable with a set of stage 3 6.0L (casting 317, i think) heads?
can i force about 15lbs of boost (blower, not a turbo) in in that motor and not destroy it?
I put this in forced induction because that is my main concern.
Thanks guys.
Old Jan 16, 2008 | 10:59 PM
2004SSS's Avatar
nope no 427 , i think the biggest ive seen was a 420 and that was pretty big, most go
.03 over and stroke it using a 4.00 crank which makes a 408.
if your using forged pistons/rods and good head studs with 9.0-1 cr 15 psi should be very reliable
Old Jan 16, 2008 | 11:04 PM
Wilde Racing's Avatar
How do I change this text
Another popular option is to save some money (and fuel mileage) and do a stock crank 4.030 bore with some high quality pistons...
Old Jan 16, 2008 | 11:15 PM
What displacement does a 4.030 with a stock crank yield, 382? I guess that might be a better plan, seeing as how 15 psi will get about 500awhp (I am running an awd sss).
Here is another question...I know that the tranny needs work, rear will need attention, but what kind of power levels can the front diff take? I know they only see about 37% of overall engine power, which makes me think that the front diff should be ok, considering 500 AWHP = 320 at the rear and 180 at the front. Opinions?
Old Jan 17, 2008 | 12:14 AM
And can the factory 317's be worked to put bigger studs in there? What's stock, 3/8's, so a bump to 7/16's or 1/2 inch would suffice?
Old Jan 17, 2008 | 12:45 AM
Give Richard at WCCH a P.M (he is a member and a sponsor) he will get ya going at a killer deal for the studs.
Front diff is unknown, as far as I know no-one has broke one yet....
Old Jan 17, 2008 | 12:57 AM
Thats the message I have been getting too. Haven't heard of one breaking, which is good.
Old Jan 17, 2008 | 01:48 AM
I did see a T-case blow apart many moons ago on this site. it was in a turbo denali I believe....
Old Jan 17, 2008 | 12:55 PM
04Denali's Avatar
WHAT!!!!!!!!!!!!!!!!!!!!!!!!
Old Jan 17, 2008 | 08:44 PM
Well, what can you expect, with the kind of power your putting through them. I have heard of a company on Long Island NY that builds GM front diffs for race apps.
That being said, I think, from what I hear, that 500 to the wheels shouldn't kill it. What about the Tcase? How do those stand elevated power levels?
