427 from a 6.0L iron block
Old Jan 17, 2008 | 08:57 PM
nightrunner's Avatar
Mr. Obvious
Originally Posted by 03 BLACKOUTSSS
What displacement does a 4.030 with a stock crank yield, 382?
that is a 370 cu. in. engine
Old Jan 17, 2008 | 09:03 PM
joshua022's Avatar
What does it take to get a 427 then??
I think there is a guy on here with and LS2 bored and re-sleeved to a 427.
Is that about the only way without buying an LS7 block?
Old Jan 17, 2008 | 09:08 PM
04Denali's Avatar
Well, what can you expect, with the kind of power your putting through them. I have heard of a company on Long Island NY that builds GM front diffs for race apps.
That being said, I think, from what I hear, that 500 to the wheels shouldn't kill it. What about the Tcase? How do those stand elevated power levels?
I know my front diff is the week link, I was saying WHAT!!!!!!!!!!!! to the Transfer case, they are rated at 2300 ft pound of Torque.
Mark
Old Jan 17, 2008 | 09:14 PM
Wilde Racing's Avatar
How do I change this text
who has broke a front diff????
BTW it was a Escalade mark.
Here is the thread. too bad the video does not work any more...
https://www.performancetrucks.net/fo...fer+case+video
This was before Performance trucks .net.......
Old Jan 17, 2008 | 09:26 PM
03 BLACKOUTSSS's Avatar
Sweet. The Tcase is pretty damn strong. Allright, so the front is the soft spot. No problem, I am not looking to get crazy power to the ground...until I get more money.
Old Jan 17, 2008 | 09:27 PM
I don't think the front is the "weak spot". .....
Old Jan 17, 2008 | 09:36 PM
well, I am planning on getting either a stage 4 or 5 4L65 or an 80. probably the 65, I like the gearing better than an 80e. spealing of trannies, if they can make a factory Tcase good to 2500 tq, why are the trannies only good for a little above stock?
Old Jan 17, 2008 | 09:52 PM
Steve Bryant's Avatar
LS1 Tech Veteran
If you're going for 15 PSI of boost, I would'nt bother with trying to up the displacement. You might want to go to 4.010" via a bore and hone and go with forged rods and pistons (maybe a crank).
Steve
Old Jan 17, 2008 | 10:00 PM
Steve
Are you talking from a money standpoint, saying that a 370ci wont make a difference over a 365? Because if thats the case, and it won't make a difference, then I'll consider that. I like saving money.
or did I totally miss the point?
Old Jan 17, 2008 | 11:12 PM
1BadAction's Avatar
Registered abuser
Steve
finally someone with some sense. 15psi on a forged 6L with a good head/cam combo should net all the power you can use on the street.
