The 420 is DONE!!!!!!!!!!
Old Sep 3, 2007 | 09:45 AM
  #281
thunder550's Avatar
High on diesel fumes
I'd say you want it to be a little rich at part throttle cruising, probably between 14.3 and 14.7, just to be on the safe side. Once you get the tune nailed down 14.7 is where you want to be when cruising, and I'd say 12.7-13.0 at WOT.
Old Sep 3, 2007 | 10:03 AM
  #282
TurboGibbs's Avatar
I run 15.5-16.5 in my cruise areas on the PE map. The american man's lean cruise.
But you can't do that Cody unless you stay in open loop and turn off the O2's.
Old Sep 3, 2007 | 05:46 PM
  #283
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Originally Posted by litreddevil
so how much does a motor build cost for them to leave one of the most important plugs out.you better pull the motor and send it back to the builderfor them to check all the bearings again,not go on the first start up.
but on the other hand congrats and hope you don't but i would pull it.
Well the biggest problem is that no matter how hard we try we are all still human and make mistakes. It sucked cleaning up almost 6 quarts of oil that spewed all over the ground and everything else that is on the driverside of the block but atleast it wasnt as bad as it could have been. If I had to do it all over again I would get the WCCH team to take care of me again they are a first class place and their customer service cant be beat. It could have been alot worse but nothing happened and everything is fine now.
If only I could figure out why my damn temp sensor wont register anything I could go drive the POS
BTW my oil pressure gauge is reading really high at idle(~72), is that what is should be Rex? Im not sure if my gauge is perfectly right after putting the overlay on but I readjusted it once already so it should be within 5psi.
Old Sep 3, 2007 | 05:52 PM
  #284
moregrip's Avatar
what a rush!
what oil pump did you run?
Old Sep 3, 2007 | 05:55 PM
  #285
1slow01Z71's Avatar
Brand new stock LS6 pump that I ported a little myself with the spring shimmed by Rex I believe is what he told me.
Old Sep 3, 2007 | 06:04 PM
  #286
moregrip's Avatar
what a rush!
is that pressure at idle in park, or idle under load?
Old Sep 3, 2007 | 06:11 PM
  #287
moregrip's Avatar
what a rush!
anyway, the way I see it without all the info, your running a higher tension spring(shimmed) and straight 40w. Some people don't like to see that much oil pressure at idle, some people don't mind it. There are reasons for both views. Long story short, I'd put it in gear, keep your foot on the brake, observe and record oil pressure; break your engine in the way Rex told you too, switch to the kind of oil you will run regularly, then re-evaluate.
You might want to drop your filter/replace it and cut it open to see whats inside just to be on the safe side.
Old Sep 3, 2007 | 06:13 PM
  #288
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by moregrip
anyway, the way I see it without all the info, your running a higher tension spring(shimmed) and straight 40w. Some people don't like to see that much oil pressure at idle, some people don't mind it. There are reasons for both views. Long story short, I'd put it in gear, keep your foot on the brake, observe and record oil pressure; break your engine in the way Rex told you too, switch to the kind of oil you will run regularly, then re-evaluate. You might want to drop your filter/replace it and cut it open to see whats inside just to be on the safe side.
sound advice
Old Sep 3, 2007 | 06:15 PM
  #289
1slow01Z71's Avatar
For some reason my brakes arent working right now either so I need to check that out too. I knew there were going to be some problems with the truck sitting for 15 months. 72 is in park and neutral.
Old Sep 3, 2007 | 06:16 PM
  #290
moregrip's Avatar
what a rush!
put it in gear, keeping your foot on the brake(i.e. load), see what happens
