The 420 is DONE!!!!!!!!!!
Old Aug 12, 2007 | 09:20 PM
  #201
TurboGibbs's Avatar
How about some carb cleaner, brake clean or laqure thinner to disolve the plastic?
Old Aug 12, 2007 | 09:30 PM
  #202
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Its not the plastic its the adhesive. The adhesive peeled off the plastic tape.
Old Aug 12, 2007 | 09:37 PM
  #203
TurboGibbs's Avatar
even better. That will come off with rubbing alcohol. A can of carb cleaner will wipe that out with no problem.
Note to self: wrap headers with news paper, then tape.
Old Aug 12, 2007 | 09:39 PM
  #204
kbracing96's Avatar
How about some 3M adhesive remover?
Old Aug 12, 2007 | 09:48 PM
  #205
1slow01Z71's Avatar
The stuff comes off easy with some nonchloro brake cleaner and a paper towel its just I cant get to all teh spots I taped off without taking the header off thats the pisser. It comes off easily its just not easy to get in a position to take it off. Ive pretty much decided Im buying a welder. I have put it off too long. Now I need to decide, milllermatic 140 or lincoln 135 pro-mig both are 110 which is all I can use since I only have a 110 plug in the garage.
Old Aug 12, 2007 | 10:02 PM
  #206
Richard@WCCH's Avatar
FormerVendor
Sorry to see your curse continue Cody.
How about dragging the truck to a local muffler shop? They can fix the..........huh, huh.........bung hole for the O2 sensor and bend up a nice Y-pipe couldn't they?
For the adhesive on the exhaust pipe get a bottle of Goo Gone from a local Walgreens or other general merchandise store. It works pretty good for a non industrial adhesive remover. If that doesn't work, then you'll need to visit an auto body paint store and get a can of 3M Adhesive Tape Remover. That stuff is the bomb especially for old masking tape.
Good luck chief
Richard
Old Aug 12, 2007 | 10:29 PM
  #207
Stoichiometric's Avatar
You can't go wrong with the miller or lincoln. If you need more than 110 power you can build a 220 extension cord to plug into a dryer outlet. For muffler tubing, the 110 is plenty.
Old Aug 12, 2007 | 10:32 PM
  #208
Tootall's Avatar
how far is the muff shop? . . . I drove a little over 6 miles with open headers.
Old Aug 13, 2007 | 08:18 AM
  #209
NegraRCSB2X4auto's Avatar
talk about bad luck.sorry
Old Aug 13, 2007 | 08:37 AM
  #210
Yogi Bear's Avatar
I hope that your luck changes for the better. Hang in there, Cody!
