The 420 is DONE!!!!!!!!!!
#203
Its not the plastic its the adhesive. The adhesive peeled off the plastic tape.
Note to self: wrap headers with news paper, then tape.
#205
Tin Foil Hat Wearin' Fool
The stuff comes off easy with some nonchloro brake cleaner and a paper towel its just I cant get to all teh spots I taped off without taking the header off thats the pisser. It comes off easily its just not easy to get in a position to take it off. Ive pretty much decided Im buying a welder. I have put it off too long. Now I need to decide, milllermatic 140 or lincoln 135 pro-mig both are 110 which is all I can use since I only have a 110 plug in the garage.
#206
Sorry to see your curse continue Cody.
How about dragging the truck to a local muffler shop? They can fix the..........huh, huh.........bung hole for the O2 sensor and bend up a nice Y-pipe couldn't they?
For the adhesive on the exhaust pipe get a bottle of Goo Gone from a local Walgreens or other general merchandise store. It works pretty good for a non industrial adhesive remover. If that doesn't work, then you'll need to visit an auto body paint store and get a can of 3M Adhesive Tape Remover. That stuff is the bomb especially for old masking tape.
Good luck chief
Richard
Good luck chief
Richard
#207
You can't go wrong with the miller or lincoln. If you need more than 110 power you can build a 220 extension cord to plug into a dryer outlet. For muffler tubing, the 110 is plenty.
