The 420 is DONE!!!!!!!!!!
#102
Got the new air compressor and got a fwe other things lined out, tomorrow afternoon Ill be hitting it hard and heavy.
A teaser pic of whats to come in a couple months after its broken in
Who polished the intake and stuff for you? Will the fuel rails and injectors fit underneath of that plate that holds the solenoids or will you not be able to use that? Looking good man!
#104
Tin Foil Hat Wearin' Fool
Im going to have to use a 1.5" spacer under the plate system to clear the rails. The purple plate is just to hold the solenoids, the black part is where the tubes for the nitrous and fuel and it also has burst panels so if some how I get a nitrous backfire those pop out and doesnt screw up my motor. Im wandering how long it will be till all the polished **** looks look ****
Progress tonight
Progress tonight
#108
Driveside manifold studs are FUBAR, one of the waterpump bolts was trying to cross thread and I was tired from staying up till 3am then getting back up at 7:30 so I called it a night. Ill have everything buttoned up tonight as long as I dont have to work late.
