4.3 to 5.7 budget build
Old May 14, 2008 | 11:02 AM
InchUp's Avatar
Originally Posted by GMCtrk
if you're spending that much to get 5.7 out of the 5.3 why not just get a LS1 pullout?
I'd rather have an iron block in a truck anyways. $550 for the block prep and bore over, $350 for the pistons and $250 for a balanced rotating assembly. When you think about it I spent $244 on the entire complete 5.3L out of the donor truck and another $550 on the block which includes cleaning, boring over, decking and truing up the block to the crank centerline, new cam bearings and all new main and rod bearings. Not bad for $550 to get a perfect foundation to build on with an iron block 5.7L.
Old May 14, 2008 | 12:52 PM
mcfarlnd's Avatar
Un-Registered User
Originally Posted by dlt76028
this way he will know about the motor and it will be like new.
Old May 15, 2008 | 10:07 PM
InchUp's Avatar
One thing to keep in mind with the 5.7L build that I've recently come across, is that your cylinder walls will now obviously be thinner therefore dumping more heat into the cooling system. Make sure your cooling system is back up to par because now you'll have to cool a motor that puts about 10-15 degrees more into the radiator.
Old May 19, 2008 | 09:23 PM
mcfarlnd's Avatar
Un-Registered User
ill keep it in mind. what bearings is everyone using? (rod and mains)
Old May 19, 2008 | 10:01 PM
chevyguy7802's Avatar
I used clevite's......
Old May 21, 2008 | 12:50 PM
mcfarlnd's Avatar
Un-Registered User
which ones?
Old May 21, 2008 | 01:00 PM
Clevite 77 rod and main bearings.....I got mine at jegs
Old May 21, 2008 | 07:28 PM
mcfarlnd's Avatar
Un-Registered User
i ended up getting federal mogul CH-series rod bearings and clevite P main bearings which i guess is part of the 77 series. whos doing your tuning?
Old May 21, 2008 | 08:00 PM
Havent got the motor into the truck yet.......i just got the motor built here recently
Old May 21, 2008 | 08:29 PM
mcfarlnd's Avatar
Un-Registered User
i have hp tuners if you need help
