4.3 to 5.7 budget build
Old May 13, 2008 | 04:52 PM
mcfarlnd's Avatar
Un-Registered User
Default 4.3 to 5.7 budget build
well a buddy of mine finally got tired of his 4.3 when he found an awesome deal on a half *** complete 5.3. the motor has been at my house for a couple weeks and finally got it tore down and to the machine shop. ill take pics as we build it up. its not too extreme just a couple things to freshen it up. no nitrous or FI. i know everyone goes 6.0 but, this will be a decent setup for sure.
06 scsb silvy
02 5.3 bored for stock 5.7 pistons.
balanced rotating assebly.
04 ecu with dbw and pedal and harnesses
ported 862 heads with dual springs
cam 228/228 .588 .588 on a 112.
ls2 timing chain set.
ls6 ported oil pump
lc-1 w/b
all new bearings and seals.
were at ? bucks right now for whats above. need to add it up
any suggestions let me know. besides tranny
oh if anyone wants to trade some returnless fuel rails for some return style let me know. we need returnless.
Old May 13, 2008 | 07:00 PM
dlt76028's Avatar
sounds good, get those heads milled some too
Old May 13, 2008 | 09:17 PM
InchUp's Avatar
Sounds very very similar to my build, going from the 4.3L V6 to the 5.3-to-5.7L V8. Check around for the "Opinions wanted 5.7L" thread I've got going, otherwise so far it seems like a very logical build.
I assume with the dual springs that you're wanting to run a cam with really high lift? Depending on which cam exactly, you may want to look into a different intake. If the truck is going to be used as a truck by all means keep the truck intake, however if this is a street truck build, some of the car intakes might be worth looking into.
Old May 13, 2008 | 09:32 PM
hirdlej's Avatar
Originally Posted by mcfarlnd
06 scsb silvy
02 5.3 bored for stock 5.7 pistons. $400
balanced rotating assebly. $150
04 ecu with dbw and pedal and harnesses $150
ported 862 heads with dual springs Stage 1 port job $400 and springs are $230 on a good deal through a vendor special
cam to be determined when i get the motor back. $330 new ebay special
all new bearings and seals. seals, gaskets, easily another $250
were at 1000 bucks right now for whats above.
I don't know how on earth you're going to do all of that, that cheap but good luck. I would plan on at least 2 grand minimum. All the little **** adds up. I'm thinking you're sitting more like: $1660-$2000
Old May 13, 2008 | 10:05 PM
chevyguy7802's Avatar
As mentioned above the little **** adds up....im finishing up the assembly on my iron 5.7 build and I have around 2,000 in just the shortblock.....
Old May 13, 2008 | 11:43 PM
mcfarlnd's Avatar
Un-Registered User
read!!! i already have that stuff for under a grand. just ran across some people in tight spots aside from the cam, sorry.
Old May 14, 2008 | 12:05 AM
mcfarlnd's Avatar
Un-Registered User
where you located in burleson. my mom lives in oak valley. also, you using forged internals in that 2,000????
Old May 14, 2008 | 12:56 AM
Yea i live in burleson close to mansfield.....Forged pistons but stock internals and upgraded rod bolts,i did a full rebuild thats why its so much.....my donor motor wasn't the cherry i was told it was lol
Old May 14, 2008 | 03:54 AM
GMCtrk's Avatar
if you're spending that much to get 5.7 out of the 5.3 why not just get a LS1 pullout?
Old May 14, 2008 | 09:20 AM
dlt76028's Avatar
this way he will know about the motor and it will be like new.
