370 vs. 383.....Need Imput
Old Sep 11, 2008 | 12:54 PM
  #21
dhpro's Avatar
Put a blower & headers on this! These motors are the best deals out there!
https://www.performancetrucks.net/fo...d.php?t=423936
Old Sep 11, 2008 | 07:15 PM
  #22
Sierra1320's Avatar
6.0 LS2 with L92 heads and L76 intake for $4895.00. I wonder what the compression is on that engine though. I'm imagining most likely around 10:1. They make rotating assemblies for LS2's of course so you could go forged with everything already there including your fuel rails, flexplace, even the plugs. Thats not a bad idea, but then of course theres the trans, rr, brakes, fuel system... Not a bad idea though.
Old Sep 12, 2008 | 12:39 PM
  #23
Sierra1320's Avatar
For the guys with the 408's. What kind of life do you get out of a 408? Reliability speaking.
Old Sep 12, 2008 | 12:45 PM
  #24
Mangled03gmc's Avatar
Baltimore Whore
The same if not more then a stock motor, as long as you maintain it proper, don't blow the rods out of the block form over boosting, or spraying it to death..
John
Old Sep 12, 2008 | 12:52 PM
  #25
dhpro's Avatar
Seriously...u shud just build ur 5.3...the stock internals on that motor have been pushed up north of 600rwhp. There really isn't any reason not to go with the stock stuff (pistons, rods, crank, rockers...etc) unless ur stroking, or boring. U can get 400+rwhp and not have to spend another $4500 on a tranny and rr end - at least not right away. Jees...I wish someone had told me all this stuff!
Old Sep 12, 2008 | 01:50 PM
  #26
GoatChs's Avatar
Originally Posted by InchUp
This is the basic idea. If you're going to start with a 6.0L block then it's not really a matter of 370 vs 383 (ls1 with a 4" crank), then it's more of the question to stroke the 6.0L instead.
So in all reality the title of this thread should be 370 vs 408. In which case I'd rather keep the 370 and spend more money on the forced induction system.
In actuality, it is titled appropriately. The OP can bore his 5.3 block to 3.905 and use the 4" crank to get 383 out of his current engine.
Thread content: I've been informed (after the fact) that my long stroke 383 is not the ideal FI setup. I agree with those that recommend using your 5.3L...bore it to LS1 specs (3.898 bore), get your assy rebalanced and away you go with a 5.7L.
Chavette
Oct 28, 2015 07:33 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
OHsixLS3
Sep 25, 2015 04:38 PM
OHsixLS3
Sep 25, 2015 11:20 AM
97_ek
Sep 23, 2015 09:16 PM
