6 liter swap?
Old Sep 10, 2008 | 10:40 PM
2ktransam's Avatar
Default 6 liter swap?
I am getting ready to do a 6 liter swap in my truck and I wanted to know what odds and ends I need. I am putting my z06 cam and springs in as well so that adds a few things. Here is what I can think. Let me know if I am missing anything.
crank bolt
manifold to collector gaskets
waterpump gaskets
front cover gasket
front main seal - just to be on the safe side
fluids and oil filter
Old Sep 12, 2008 | 07:47 AM
2ktransam's Avatar
Anybody?
Old Sep 12, 2008 | 07:56 AM
sickREDsierra's Avatar
there are several stickies on this subject.https://www.performancetrucks.net/fo...d.php?t=414374
use that search button my friend.
Old Sep 12, 2008 | 08:34 AM
GMCtrk's Avatar
Honestly, the 6 liter swap requires damn near nothing. I even reused the water pump gaskets. All I can think of is coolant and oil/filter.
Old Sep 12, 2008 | 10:35 AM
zippy's Avatar
Go to your GM dealer and get a gasket kit part number 12499228. This will come with a crank bolt, intake gaskets, valve cover gaskets, front cover gasket, crank seal, and water pump gaskets. It is known as their cam change gasket kit. From there I'd get 2 gallons of Dexcool, 2 bottles of Water Wetter, 7 quarts of oil, 1 bottle of GM EOS for installing the camshaft, and some trans fluid in case you take out the converter.
Old Sep 12, 2008 | 02:10 PM
10 Second Truck Club
good luck on the swap, i am doing a swap as well
Old Sep 12, 2008 | 02:40 PM
kingots2004's Avatar
its easy i changed mine by myself except for about one hours worth of work in 8 hrs.also i had a rack to lift it and do my stuff under the truck
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
XL7
May 5, 2022 01:48 PM
dry_kill
11
Aug 28, 2015 09:53 PM
MileHighSierra
Jul 22, 2015 11:19 PM
bsgiffor
Jul 19, 2015 11:14 AM
