370/MP122 Build
Old Jul 7, 2008 | 02:51 PM
  #191
dhpro's Avatar
Special thnx to Mark aka TRANNYMAN and Butch from the CT Avalanche Chapter for giving the the tutorial at Dr Nicks Transmission in Milford! These guys are full of info on these motors and they're the ones who recognized my oil probs right away. Swapped out my Moroso pan and remote filter for a stock unit. Was getting oil aeration due to the pick-up O-ring being the non-GM OEM piece...obvious difference in thickness. Results were remarkable...idle smoothed out, power curve feels steeper, and oil temps dropped by 30-40*. Most important got rid of the leaky remote fittings. Also removed my oil cooler; 2 reasons - First forget to get the new fitting to install it with the stock unit, second...was suggested that less travel and external fittings might be a good thing. Certainly hasn't hurt! One less bug!
Old Aug 4, 2008 | 06:50 AM
  #192
dhpro's Avatar
Ordered CTSV Heat Exchanger...lets see what if this helps get temps down! Cahnged to Amsoil 20/50 and smoothed out the power curve a little more by SOTP and added a few pounds of running oil pressure (60lbs @ 2200RPM cruise - About 75-80mph.
Old Nov 12, 2008 | 07:40 AM
  #193
dhpro's Avatar
Update: 496rwhp/555torq @ 8lbs on dynojet yest....Thanx to Brian at Magnusson new CTSV exchanger installed - found the old one was pretty gunked up and the bigger unit and better flow really helped! All electrical gremlins are fixed (AC, lites, 4wd...etc), except foer the TB. Havent had the "reduced power" msg in a while and traced it to a bad connector on the TB itself - Richard @ WCCH tracked down a new one and shud be en route! Tie wrapped the TB harness up tight temporarily and seems to be jerry rigged for the moment. Its away for the winter now and we'll see about a little work on ramping up boost, 8 rib pulley install and general tweaking early in 09. I'm just happy its finally working out the bugs. R/
Old Nov 12, 2008 | 08:10 AM
  #194
leftcoast32's Avatar
FormerVendor
Glad everything is coming together!!
Old Nov 12, 2008 | 08:17 AM
  #195
dhpro's Avatar
Thnx Joe! Your help and advice were very welcome...R/
Old Nov 13, 2008 | 02:37 PM
  #196
Go5.3tt06's Avatar
Originally Posted by dhpro
Just need to index the cam and adjust lash...MP122 is here and just waitin on the 4l80!
PS...my 1st time using this photbucket so lemme know if its messed up!
Hey where did you get oil pan. I like it.
Old Nov 13, 2008 | 03:40 PM
  #197
dhpro's Avatar
Trust me, u dont want one...had to have it altered to fit the 4x4 (actually they did a great job - see the pix). I went back to the OEM part and got rid of the remote filter and hassles.
Old Nov 14, 2008 | 01:53 PM
  #198
Go5.3tt06's Avatar
Oh got it, Thanks
Old Nov 21, 2008 | 04:29 AM
  #199
kylloso's Avatar
damn i got a headache just readin about all ur problems on this build and almost wanted to hang myslf since im goin with a forged 370 with a 122 maggy as well but just readin up on builds from different ppl with 370s to see wut i can avoid before divin head first glad to hear its out and about and acting more manner like instead of giving u those hassles glad my tuner knows his chet enought to spec me a cam as well and will even come to my house if needed to turn my truk on and get it tuned and dyno is only down the street for me and in my area the trukin scene owns all cant go to the corner stor without bein romped at by another fast gm truk alot of shops here are familiar in the trukin scene
MOBBN
Sep 22, 2015 08:07 PM
2500ZL1
Sep 12, 2015 03:50 PM
MA$TER_E
Sep 9, 2015 03:14 PM
iregret
Sep 7, 2015 01:20 PM
