370/MP122 Build
#191
Special thnx to Mark aka TRANNYMAN and Butch from the CT Avalanche Chapter for giving the the tutorial at Dr Nicks Transmission in Milford! These guys are full of info on these motors and they're the ones who recognized my oil probs right away. Swapped out my Moroso pan and remote filter for a stock unit. Was getting oil aeration due to the pick-up O-ring being the non-GM OEM piece...obvious difference in thickness. Results were remarkable...idle smoothed out, power curve feels steeper, and oil temps dropped by 30-40*. Most important got rid of the leaky remote fittings. Also removed my oil cooler; 2 reasons - First forget to get the new fitting to install it with the stock unit, second...was suggested that less travel and external fittings might be a good thing. Certainly hasn't hurt! One less bug!
#192
Ordered CTSV Heat Exchanger...lets see what if this helps get temps down!
Cahnged to Amsoil 20/50 and smoothed out the power curve a little more by SOTP and added a few pounds of running oil pressure (60lbs @ 2200RPM cruise - About 75-80mph.
#193
Update: 496rwhp/555torq @ 8lbs on dynojet yest....Thanx to Brian at Magnusson new CTSV exchanger installed - found the old one was pretty gunked up and the bigger unit and better flow really helped! All electrical gremlins are fixed (AC, lites, 4wd...etc), except foer the TB. Havent had the "reduced power" msg in a while and traced it to a bad connector on the TB itself - Richard @ WCCH tracked down a new one and shud be en route! Tie wrapped the TB harness up tight temporarily and seems to be jerry rigged for the moment. Its away for the winter now and we'll see about a little work on ramping up boost, 8 rib pulley install and general tweaking early in 09. I'm just happy its finally working out the bugs.
R/
R/
#196
#197
Trust me, u dont want one...had to have it altered to fit the 4x4 (actually they did a great job - see the pix). I went back to the OEM part and got rid of the remote filter and hassles.
#198
#199
damn i got a headache just readin about all ur problems on this build and almost wanted to hang myslf since im goin with a forged 370 with a 122 maggy as well but just readin up on builds from different ppl with 370s to see wut i can avoid before divin head first glad to hear its out and about and acting more manner like instead of giving u those hassles glad my tuner knows his chet enought to spec me a cam as well and will even come to my house if needed to turn my truk on and get it tuned and dyno is only down the street for me
and in my area the trukin scene owns all cant go to the corner stor without bein romped at by another fast gm truk alot of shops here are familiar in the trukin scene
MA$TER_E
Sep 9, 2015 03:14 PM
iregret
Sep 7, 2015 01:20 PM
