232/236 612/619 114 in a 408?
I just received my cam from Comp Cams. It was supposed to be a
232/236 595/602 114 but this is what I got. 232/236 612/619 114 sounds good to me but I just want to make sure I don't bend anything.
My build is :
2003 SSS
408 stroker with Eagle kit, 4.030 bore size, 6.125 rod lenght, -2cc flat top pistons.
World Products Cylinder Heads. 72cc, 235cc Link : http://www.worldcastings.com/prods_p...arhawkls1x.htm
CR 10.6 :1
1.75:1 Pro-Magnum Rocker Arm Kit (adds about .008 lift)
Pro Magnum Hydraulic Roller Lifters
Hi-Tech™ Pushrods 7.4" x 5/16"
Accel High Impedance Injectors 62 lbs/hr 74620S Link : Accel Injectors
My build is :
2003 SSS
CR 10.6 :1
Only thing you left out is what size stall. I think that is a damn good cam especially if you put alot of city miles on the truck. If it is just a weekend warrior that mileage isnt a concern then you could step it up a few degrees more depending on the stall speed you go with.
same thing happened to me when Richard ordered my cam from comp. They mixed up the lobe numbers which through off the int and exh lift. I would have them regrind you a new cam that is what you ordered.
Yeah, those are warranty parts and the motor is being build as we speak. I can live with that. It's different cam for sure. I was more concerned for the heads VS high lift.
I called World Castings and they will tolerate a 10% higher lift. (that's 660).
I run a cam pretty close to that lift. Just clay a cylinder to be sure and check those pushrods (as I recall 7.4 was too long for me but I have accelerated lift Crane rockers so may be a little different)
Aren't the new grinds like that a bit? The new high lift from futral is very close.
I wonder if there is more air coming in the cylinder with more lift but the same duration...
TAPyvehc93
Dec 27, 2015 12:14 PM
