What size converter are you turbo guys running?
Old Sep 10, 2015 | 03:11 PM
TAPyvehc93's Avatar
Default What size converter are you turbo guys running?
Im just curious as to what everybody else is running. I know it depends on the setup. I myself have a 75/75 on a 5.3 with a 224/228 @114 and Im running a 2800 yank with a 3.42 gear (6l80 BTW).
Old Sep 10, 2015 | 06:00 PM
walledition's Avatar
74/75 on a 6.0 with a 224/224 @112 and Im running a 3600-3800 circle d with a 4.10 gear 4l80e, im at 7000ft above sea level and it spools quick with a converter this loose
Old Sep 11, 2015 | 02:55 AM
sTNT971's Avatar
Circle D Multi Disk , 6l80e pro stage 258mm /stall 3200
with stator option to build boost
Old Sep 11, 2015 | 10:33 PM
Sevex's Avatar
Snail Fab
5.3, billet 80mm with a triple12 cam, 4l80 with 3.73's. Jarrett spec'd a 3400 yank triple disk when I ordered the cam.
Old Sep 12, 2015 | 01:52 PM
kbracing96's Avatar
Circle D 265mm triple disk, 3A Stalls about 3600 in my truck in boost. I really like it. I like a tight converter though, wouldn't mind it one bit if it was a 2A.
Old Sep 13, 2015 | 12:58 PM
ZO6Ted's Avatar
Had a PI 9.5" 3k triple in my 07. It would flash to 28-3000 but would brake boost to 4400. It was too loose for my liking so I had it tightened to flash to ~ 2400 and brake to ~ 3500. I liked it MUCH better as a DD. In storage.
Old Sep 13, 2015 | 08:21 PM
Choda's Avatar
70mm trick stage 2 kit. Stock 5.3. 4l60 w 3:42. Had a yank TT3000 which stalled around 3500 and did 1.7 sixty foots.
Just ordered a FTI street bruiser 11inch 3000 stall.
Old Sep 16, 2015 | 09:18 PM
GMCSIERRA5.3's Avatar
Choda if i were you i would not get the street brawler id go with the circle d 278mm instead call chris and have him show you there bearing and what they use..i just had the 2nd street brawler mess up in the passed 2 months both with the bearing coming apart and ruining both transmissions..however i have used about 8 of them with goodluck but 2 failures back to back is not acceptable for us
Old Sep 16, 2015 | 09:24 PM
First picture ate the stator with 2 weeks of use..second pic is from a tbss... Name:  6D9AF8EE-8E6A-4B60-8D78-200E523F95A9.jpg
Size:  280.3 KB Name:  040DFCC6-4851-46F5-BC7E-2AFB78C262BD.jpg
Old Dec 26, 2015 | 09:20 PM
2001LS1WS6's Avatar
Registered User
Would those two failures be from vehicles equipped with turbos? The only reason I ask is because I was looking at the Street brawler for my 2001 trans am with bolt ons.
