228r cam with 1.8 rocker arms
Old May 23, 2011 | 06:48 PM
ou812sm's Avatar
Default 228r cam with 1.8 rocker arms
What will be the total lift if I went to a 1.8 rocker ARM how will it effect the way th cam works the cam specs to 228r is
228/228 .588/.588 will this be something worth doing
Old May 23, 2011 | 06:56 PM
WICKEDOWESIX's Avatar
622.58" will be your new valve lift if you use 1.8 rockers. Not really woth it IMO. Yor are better off getting a cam that has the lift you desire with 1.7 rockers. Also a side note TSP does not recommend 1.8 rockers with that cam due to the fast ramp rates of the lobes.
Old May 23, 2011 | 06:59 PM
06murder's Avatar
stock rockers r just fine
Old May 23, 2011 | 07:02 PM
ou812sm's Avatar
Just trying to squeeze a more power out of my current setup
Old May 24, 2011 | 01:17 AM
06Sierra2's Avatar
just run a custom ground cam with similar duration and more lift. spend the money on stock ratio roller rockers or get the comp trunion upgrade for the stockers.
06Sierra2's Avatar
what is your current setup other than the 228r cam? more details please...
Old May 24, 2011 | 12:00 PM
ou812sm's Avatar
My current set is
6.0
228r cam
L92 heads milled 30thds
Truck intake
42# injectors
Circle d 3500 triple clutch tq
Plus bolt-ons
Old May 24, 2011 | 04:25 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Before you consider adding lift, you need to know where the max flow of your heads is. If you max lift is at .575, adding more lift to your current cam may hurt performance, not help it.
Speccing lift requires knowing that max flow point is in lift. Then you get slightly more lift, so you are hitting that max flow point twice per valve event (e.g. keeping it open at max lift for twice the amount of time than if you match your max lift point). Going past that point can hurt you if the heads flow poorly with that much lift.
Have you done long tubes? If not, add 1 7/8s LTs. If so, if you didn't do 1 7/8s, sell whatcha got and go big
You could also go to a fast 90/90 or 105/105 for more power.
The_W
Oct 28, 2015 09:00 PM
superchomper2003
Aug 26, 2015 09:39 AM
DrX
Aug 19, 2015 04:45 PM
BigEd_72455
Aug 8, 2015 07:37 PM
maxspeed05V
Jul 19, 2015 07:08 PM
