228 / 232 .600 112lsa in a 5.3?
Old Aug 5, 2018 | 02:28 AM
Mconcha's Avatar
This cam:
216/226 .600/.600 114lsa
In my 5.3 ccsb 2wd, 4l65, 2600 stall, 3:73 gears, 285/70/17
was an a absolute dog
completely disappointed
felt slower than stock
Return what you have if possible and don’t look back.
Old Aug 5, 2018 | 02:32 AM
Mconcha's Avatar
Originally Posted by 00pooterSS
You'll wish you had done a smaller cam, a bigger converter, or both when it's done..
...x2
Old Aug 12, 2018 | 12:30 PM
TahoeNate's Avatar
Originally Posted by BlackPanther6.0
Have a friend with a crew cab 5.3 ported 243s and 4.10 gears. He had the TB converter and I talked him into a 3600 stall, and it does ok. Look into the 8.1L injectors or even the marine version ones. 255lph walboro pump will be fine
Ive been looking at the marine 8.1's . Do you have experience with them?
Old Aug 12, 2018 | 01:07 PM
BlackPanther6.0's Avatar
As a matter a fact I'm currently running those they are doing great in my 6.0 I maxed out the 8.1l # ones and upgraded to those
Old Aug 16, 2018 | 04:27 PM
TahoeNate's Avatar
pn? I saw a matched set on ebay for less than 100 29lb a hour if i recall
Old Aug 28, 2018 | 11:51 AM
hunterbohanan23's Avatar
Originally Posted by Mconcha
This cam:
What was wrong with it? No low end, mid range, top end? Cam specs aren't bad at all for a 5.3. Stall seems small regardless though for a stock cam or aftermarket cam IMO.
Old Nov 9, 2018 | 03:24 PM
tim wellington's Avatar
Default cam
same cam i run in my 370 plus engine's to much for a 5.3
Old Nov 15, 2018 | 08:06 PM
Mconcha's Avatar
Less low end and mid range than the stock cam. The truck felt more responsive and was quicker out of the hole when it was
stock with the 2600 stall. Didn’t want to make the jump to a 3000-3200 stall for daily drivability.
Thr truck is in the process of a Thompson MS 370 w/ 11:1 cr and I’ll be reusing the same cam/ stall, should be promising.
I’ll check back in with the results.
low2001gmc
May 25, 2011 05:57 AM
Phantom
Mar 5, 2009 08:28 PM
Phantom
Feb 14, 2009 05:45 AM
black03stepside
Apr 13, 2007 12:50 PM
