228 / 232 .600 112lsa in a 5.3?
Recently ordered a 228/232 .600 112lsa cam for my 5.3 with the understanding it is a aggressive cam for my ccsb with a built 4l70e with a 2800 stall. Also ordered stage 2.5 heads from tsp along with pretty much every other supporting internal short of the rotating assembly. Since reading a little more in depth I’m curious of opinions on this setup and what I should expect. Thanks in advance.
Have a friend with a crew cab 5.3 ported 243s and 4.10 gears. He had the TB converter and I talked him into a 3600 stall, and it does ok. Look into the 8.1L injectors or even the marine version ones. 255lph walboro pump will be fine
