228 / 232 .600 112lsa in a 5.3?
Old Aug 1, 2018 | 06:52 PM
T4nier210's Avatar
Registered User
Default 228 / 232 .600 112lsa in a 5.3?
Recently ordered a 228/232 .600 112lsa cam for my 5.3 with the understanding it is a aggressive cam for my ccsb with a built 4l70e with a 2800 stall. Also ordered stage 2.5 heads from tsp along with pretty much every other supporting internal short of the rotating assembly. Since reading a little more in depth I’m curious of opinions on this setup and what I should expect. Thanks in advance.
Old Aug 1, 2018 | 07:03 PM
FFDP's Avatar
Maybe a little big in a 5.3?
Don't forget about fuel too, like injectors if you haven't thought about it yet.
Old Aug 1, 2018 | 07:55 PM
matte99's Avatar
Definitely going to want more than a 2800 stall. What gears do you have?
Old Aug 1, 2018 | 08:04 PM
T4nier210's Avatar
Registered User
That’s what I’m starting to see but also some say it works well. I haven’t looked much into fueling but I know it’ll need to happen at some point.
T4nier210's Avatar
Registered User
running 3.73s with a truetrac
its a cheaper stall. I know I’ll end up with a circle d probably in the 3200 to 3600 range?
Kinda just want to see what it’ll do on the dyno at this point.
Old Aug 1, 2018 | 08:10 PM
FFDP's Avatar
For sure the stock injectors won't support the power that cam/heads combo can make, they are just too small.
Old Aug 2, 2018 | 04:20 AM
madmann26's Avatar
It's too big for a 5.3. It'll pull great above 4k but below that it'll be lackluster.
You're going to need a bigger stall, at least a 3400.
Big cams and heavy trucks don't mix well.
Old Aug 2, 2018 | 09:01 AM
Vortec350ss's Avatar
Its pretty damn big, and way too big for that converter. You'll be happier with something smaller. It will be a dog down low which really puts a damper on the fun factor.
Old Aug 2, 2018 | 09:39 AM
BlackPanther6.0's Avatar
Have a friend with a crew cab 5.3 ported 243s and 4.10 gears. He had the TB converter and I talked him into a 3600 stall, and it does ok. Look into the 8.1L injectors or even the marine version ones. 255lph walboro pump will be fine
Old Aug 2, 2018 | 05:26 PM
00pooterSS's Avatar
You'll wish you had done a smaller cam, a bigger converter, or both when it's done..
