212/218 hi lift in a stock 5.3
Old Aug 19, 2009 | 11:36 AM
skyhighsami's Avatar
no title here
Default 212/218 hi lift in a stock 5.3
I have a 5.3 in my wife's Yukon. I am building an iron LS2 for it. I have a 212/218 high light cam that I was going to put in a LS1 with some TEA Stage 1.5 heads that I am swapping in my Samurai. Anyway, I was curious how that cam would work in the 5.3 while I am waiting for the LS2 to be done and the rest of the parts to get here for the LS1. I would need some LS6 springs, but would be using the stock stall now and manifolds unless I find some headers soon. Would the cam swap net enough extra power to be worthwhile? Or would it be better to throw on the TEA heads even though they have a 59cc chamber? The only reason I am looking at this is because Stacey's truck is a slug off the line and down shifts a lot on the interstate at speed. It has a Vengeance Tune, Magnaflow muffler and 3.73 gears stock.
Old Aug 19, 2009 | 12:17 PM
slowlsx's Avatar
that sounds like a good low range cam, so i would say throw it in there!my buddy has a 220-220 and it makes good power downlow evan with a stock stall so i would think that 212/218 would make better power downlow... good luck!
Old Aug 19, 2009 | 12:43 PM
03 BLACKOUTSSS's Avatar
High lift = more than LS6 springs...what kind of lift are you talking? Highest ive seen on LS6s is around .560"
Old Aug 19, 2009 | 01:22 PM
MPFD's Avatar
11 Second Truck Club
yeah I think you gonna want more spring to be on the safe side. I'm running ls6 yellows on my 212/218 but its the old low lift version.
Old Aug 19, 2009 | 03:54 PM
Coban's Avatar
High lift is .558"/.563"
I have this cam in my stock stalled 5.3 ext cab with 3.23s. It isn't that quick off the line. It was a blast when I had 4.10s although I have never gotten the tires to squeal on takeoff.
It DOES pull strong to 6300 where I shift at. I didn't really notice a difference in low end with the cam, so I'm not going to say it would help in that department. I'd kinda like to try the low lift version just for comparison's sake.
My next motor will be a LQ9 with 243 heads and I'm wanting to reuse this cam. Should make for good low end in that motor and still enable it to breathe.
Old Aug 19, 2009 | 04:09 PM
GMCtrk's Avatar
This is pathetic. My condolences and I hope you get that 6.0 sooner than later
Old Aug 19, 2009 | 06:21 PM
Coban's Avatar
Hey now, at least they squeal when the turbo spools up.
There is something to be said about the sheer torque of a larger motor. Hopefully high compression will make it even better.
FI just complicates things, I had my fun.
And I don't believe in aftermarket TCs.
Old Aug 20, 2009 | 12:38 PM
MPFD's Avatar
Like that they exist, or just not gonna spend the money?
If I knew then what I know now, a Yank would have been my second mod, behind spray. I mean maybe even before the "free" mods cause most of those are all BS anyway. I would definatly would not do a cam before a converter again! My 3600 dropped a full second off my E.T.!
Old Aug 20, 2009 | 02:39 PM
Coban's Avatar
No no, I believe they exist. I just don't believe in using them as a quick fix for an awful bottom end. I'm looking for torque now.
Also, I don't like the added stress they create.
Also, I would rather have as many OEM parts as possible.
Also, I'm not building an all out race truck. I just like to have fun while in cruising around.
To each their own.
Old Aug 20, 2009 | 02:51 PM
AdioSS's Avatar
12 Second Club
Coban, did/do you run that cam in a naturally aspirated combo?
