2008-2009 corvette LS3 cam
Old Apr 16, 2009 | 04:59 PM
Bill Reid's Avatar
Originally Posted by Bill Reid
Thats a 4x trigger... goes with the 58x reluctor wheel...
Below on the left is an LS2 sprocket... look at the trigger pattern vs. the (early) LS7 sprocket on the right. Note the LS7 sprocket on the right has the same trigger pattern as the single bolt sprocket sprocket shown above. The LS2 1X trigger pattern is a must... if you are running a 24x reluctor wheel on the crank. So, what I'm not sure of is if an LS2 1X trigger style cam sprocket is made with a single bolt.
Old Apr 22, 2009 | 08:01 AM
white lightning SS's Avatar
I dont think there is a compatable cam sproket for the old crank reluctor. IMO there are many easier ways to go. If you are worried about cost use a LS6 cam instead.
Old Apr 22, 2009 | 11:09 AM
sickREDsierra's Avatar
basically, not worth fawking with
Old Apr 22, 2009 | 06:28 PM
L7 Sierra's Avatar
If you really want that cam get Comp to make you one with the correct sensor positions.
Old Apr 23, 2009 | 11:27 AM
LOL or just buy one of the ten bajillion ls1 gen iii cams that are already available
OHsixLS3
Dec 27, 2016 09:30 AM
TXsilverado
Nov 26, 2015 10:54 AM
The_W
Oct 28, 2015 09:00 PM
Silveradorst07
Aug 15, 2015 03:47 PM
Denali08
Aug 9, 2015 04:34 PM
