2008-2009 corvette LS3 cam
Old Apr 16, 2009 | 07:20 AM
LaPompisRGV's Avatar
Default 2008-2009 corvette LS3 cam
will the stock LS3 cam from a 2008 2009 vette fit in my 4.8.i know i would need ls6 springs but would i need to do anything else
Old Apr 16, 2009 | 08:16 AM
ttttttt
Old Apr 16, 2009 | 08:23 AM
Coban's Avatar
Its a GEN IV engine. So I think the Cam position sensor is on the timing cover. You'd have to get an extension harness. Also, it only has 1 bolt on the cam gear vs 3 on the Gen III engines.
This is assuming you have a GEN III engine. What year is your truck?
Old Apr 16, 2009 | 08:30 AM
Originally Posted by coban
its a gen iv engine. So i think the cam position sensor is on the timing cover. You'd have to get an extension harness. Also, it only has 1 bolt on the cam gear vs 3 on the gen iii engines.
This is assuming you have a gen iii engine. What year is your truck?
2002 4.8
Old Apr 16, 2009 | 08:36 AM
Phantom's Avatar
11 Second Club
That cam is way to small to be runnin around in the rgv...
Old Apr 16, 2009 | 09:26 AM
Coban's Avatar
Yea, you have a gen III. Get a cam from the classifieds.
Old Apr 16, 2009 | 09:46 AM
Tootall's Avatar
it will work, but you will need better than LS6 yellow springs
a single center bolt cam gear
LS2/LS3 or up front cover with the sensor
extend your cam sensor from the rear to the front, with a harness or on your own
Old Apr 16, 2009 | 10:29 AM
Bill Reid's Avatar
Is there a single bolt cam sprocket with a 1X trigger?
Old Apr 16, 2009 | 02:03 PM
Tootall's Avatar
Old Apr 16, 2009 | 04:55 PM
Bill Reid's Avatar
Thats a 4x trigger... goes with the 58x reluctor wheel...
