09 5.3l cam swap, afm & vvt delete
Old May 22, 2016 | 10:22 PM
  #111
Taylor Bickett's Avatar
Originally Posted by Wolftrk99
Ummm afm not being cut off would be a big problem....could cause the bogging too!!!
Ya, I clearly stated in my email that I was doing an AFM delete... I'm really hoping it didn't do damage. I know when I started it the oil pressure was up so I thought something was blocking the sending unit screen. But when I went to slow down to turn back around to get to my farm I noticed it turned to v4 mode in my DIC. Didnt sound any different but my oil pressure dropped to 30 psi once it turned to v4 mode.....
Old May 23, 2016 | 08:09 AM
  #112
Wolftrk99's Avatar
There shouldnt be any screen forbthe sending unit anymore.... That goes away with the vlom being removed...
Old May 23, 2016 | 08:36 AM
  #113
you are right... also how could afm be working if i dont have the connector plugged into anything??
Old May 23, 2016 | 08:58 AM
  #114
Wolftrk99's Avatar
Cuts fuel and spark to the afm cylinders....
Old May 23, 2016 | 09:10 AM
  #115
ahhh... that could be the problem here.. Hopefully my revised tune comes this week and AFM is shut off.
But i shouldnt notice it on acceleration. The best way to describe it is it kind of seems like jake brakes are on in a semi lol but it will still pick up rpm and once it gets to 2800-3000 rpm it will start to sound alot better.
Old May 23, 2016 | 09:31 AM
  #116
Mikekennedy0789's Avatar
Registered User
Default Wiring harness
Quick question guys, I'm building a 05' 5.3 to put in my 00' Silverado.. It currently has a 4.8 in it, will the wiring harness off the 4.8 work if the 5.3 is a 05' model??
Old May 23, 2016 | 11:43 AM
  #117
Wolftrk99's Avatar
Yes, biggest difference would be the tb on the 05 but if youre using your stock intake and tb youll be fine.... 00 and 05 are sane basic engine so long as you dont have one of the few gen iv blocks that they released that early...usually iirc in trailblazers and some vettes...i built an 04 6.0 to swap into my 99
Old May 24, 2016 | 02:58 PM
  #118
so he assured me that AFM was shut off.. If it was i wouldnt think the DIC would change between v8 and v4 would it? When i had my last tuner in my pickup to shut off AFM it never changed out of v8 mode.
I would email him back but i dont want to push my log file and tcm tune back to the end of the line...
Old May 24, 2016 | 03:03 PM
  #119
Wolftrk99's Avatar
It shouldnt just have him double check it because its still switching, that or try to flash it again and see what happens
Old May 24, 2016 | 03:30 PM
  #120
i put in my recent email with my data log that AFM was still switching. And I did try to flash it a few times. First time i thought i did something wrong because i hardly pressed the button and it was pretty much done. still had me remove the key and wait 15 seconds though. hopefully i will get my revised tune by friday and hopefully its turned off lol
