Lowered 2014
Old Apr 14, 2014 | 09:11 AM
Noah Burns's Avatar
Looks nearly identical to mine lol, white bumper cap and different wheels On mine.
I did the shackles and blocks too but mine looks a little lower than that. May be in my head though
Old Apr 14, 2014 | 09:14 AM
racerkvn's Avatar
Originally Posted by Noah Burns
I've been thinking about this idea of relocating the strut mount to the bottom of the LCA, my only issue/concern is that rather than having the LCA under the mounts to hold the weight of the front end, it would only have the 2 bolts holding it up to the LCA once relocated. That kinda gives me an uneasy feeling, hard bumps etc might eventually cause a failure of the hardware being used and that would not be a good day
Grade 9 hardware is what comes with the kit. I have 2" drop spindles and adjustable struts sitting in my garage and opted to try this route to see how it does. I certainly can't say it won't fail even with Grade 9 hardware and I had the same reservations about it too, but so far, over a month and 2800 miles including a nice road trip, I've been pleased. No bump steer at all and rides no different from stock. I lowered the whole truck for $88 + alignment ($44 shipped on the shackles and $44 shipped on the strut kit).
My Mcgaughy's shackles were 2" drop.... sure wish I would have went with 3" but I only have "about" .250" space between my shackle and bed seam with the 2" shackle, I'm not really sure if a 3" shackle would fit even cutting the seam off flush to the bed floor.
Old Apr 14, 2014 | 09:19 AM
Bit's Avatar
Bit
Will you post a pic of your truck. 3" shackles fit on mine. They where a little tight even after cutting the lip.
Old Apr 14, 2014 | 09:27 AM
Noah Burns's Avatar
Wait, so someone makes a kit to mount the stut under the LCA?
Old Apr 14, 2014 | 10:27 AM
Bit's Avatar
Bit
Yeah, Rough Country makes it. All it is, is there leveling kit on the bottom of the lower control arm.
Old Apr 14, 2014 | 10:59 AM
racerkvn's Avatar
I know the reg cab's sit higher, but I just wouldn't have thought there would be that much difference. I'll have to take a picture of the space between my 2" shackle and the bed seam, but I can't fit my finger between them. I even had to slightly bend the seam to get the shackle bolts back in.
Old Apr 14, 2014 | 11:04 AM
racerkvn's Avatar
It's not quite their leveling kit although the same principle except remounted under the control arm. The 2" level uses a 3/8" spacer and 2" lowering kit uses a 1/4" spacer. And with that being said, I would NOT go any thicker than 1/4" spacer to lower it. I machined some thicker ones myself to "try" and the geometry was WAY out of whack.
Old Apr 14, 2014 | 01:19 PM
Bit's Avatar
Bit
Great info to have!
BCraven1018
Nov 2, 2015 07:18 AM
hodge9386
Oct 25, 2015 01:26 PM
GMCtrk
Oct 5, 2015 11:18 AM
vmaxpro
Sep 28, 2015 11:10 AM
97_ek
Sep 23, 2015 09:16 PM
