Anyone Install An Eaton TruTrac in a 2014+ 12-Bolt ?
Anyone done one using the East Coast Gear Supply ring gear spacer? How did it work out? My local driveline shop says he has had issues with these and doesn't recommend installing them.
Gear & Posi Packages - General Motors - GM 9.5" 12 Bolt - Ron's Machining Service
https://eastcoastgearsupply.com/i-23...true-trac.html
I too have asked this question without much response. There are a couple of guys on here and other gm forums that have used these exact spacers and had zero issues. I called ECGS and spoke to tech support about the same concerns you have and in a nut shell as long as the shop installs it correctly you should have nothing to worry about. They told me they have sold hundreds of these kits and have not had 1 truck back in for issues. He did however clarify that it isn't the most ideal way to do a gear swap but for us guys with 3.08 rear ends, we have no other options. The techs opinion was that as long as you're not running crazy HP numbers and your not doing neutral drops, the spacer can be trusted. He said the factory G80 is more likely to fail than the ring spacer. I plan on swapping to 4.10 by years end and I'll have to use the spacer... I'll keep ya posted
JoeyGC5
Feb 13, 2014 08:23 PM
lycominghunter
Jan 17, 2013 10:59 PM
Moddoo
Nov 25, 2006 08:58 AM
