Detroit TruTrac vs. Eaton LSD
Old Jan 13, 2009 | 10:31 PM
budhayes3's Avatar
PT's Slowest Truck
Default Detroit TruTrac vs. Eaton LSD
Looking for pros and cons of both, and maybe some insight as to how they function. I was under the impression that the trutrac functioned similar to a conventional LSD, but just read that it sends power to the one wheel with the most traction, but the LSD will lock both until a certain speed. All info is welcomed
Old Jan 13, 2009 | 10:35 PM
Mangled03gmc's Avatar
Baltimore Whore
The tru trac, has no clutches in the rear, like a conventional LSD or eaton unit. It is all gears inside it... But works on the same aspect. When power is supplied the gears act as the clutches do in a eaton lsd unit.. Also it is just about bullet proof(tru trac)
Old Jan 13, 2009 | 10:36 PM
D_reks{5.3}'s Avatar
I would also like some info to understand the 2 better..
Old Jan 13, 2009 | 10:40 PM
00ChevyScott's Avatar
Wearin' da big hat
+1 for the Truetrac.
Old Jan 13, 2009 | 10:41 PM
GMCtrk's Avatar
I just got my trutrac today. holy **** this thing is like a solid chunk of metal...very heavy. I didn't even consider the Eaton since most people here recommend the trutrac with very good results at the trac
Old Jan 13, 2009 | 10:43 PM
viciousknid's Avatar
Where's the Beef?
I've always heard Detroit Trutrac, but never Eaton trutrac. Is there a difference other than manufacturer? I just realized today that my trutrac says Eaton on it, but Tyler's was a Detroit.
Baltimore Whore
Another vote in the chunk of metal.. FYI eaton makes both of them
Old Jan 13, 2009 | 10:48 PM
silver-mod-o's Avatar
Hunt&Fisherator
I like the idea of the engagement made by worm gears versus the clutches.... Less to wear out, probably fewer moving parts...
I know my tru-trac sitting here is a VERY substantial unit, I don't see myself having problems with it, ill probably swipe a ring gear clean before this thing breaks.
Where's the Beef?
ahhh. that explains it.
Googled. it. Detroit is made by eaton.
Old Jan 13, 2009 | 10:50 PM
GMCtrk's Avatar
BTW, I read through the manual looking for where it said to beat on it to break it in....someone posted that it said this...I couldn't find it
