Sneaky Silverado
Old Feb 17, 2013 | 04:38 AM
  #181
dick_landy's Avatar
I haven't got a clue as to what it's worth, I'm thinking 5-600 bucks. I'm thinking the inlet from a whipple would be the easiest, if I don't hear back by Wednesday I'll give both a call.
Old Feb 17, 2013 | 08:14 AM
  #182
Choda's Avatar
Awesome thread man. Good luck
Old Feb 18, 2013 | 11:04 PM
  #183
dick_landy's Avatar
Lysholm wants $245 plus shipping for the Camaro inlet and Whipple wants $400 plus shipping for their truck inlet. Upon some research, neither are a bolt on deal. The bypass valve bung on both inlets would have to be reworked. I'm going to look into reworking my inlet by cutting it and adding material to open it up and put a new flange on it. Guys with Whippled Cobra's have done similar rework so it is possible.
Old Mar 13, 2013 | 06:20 PM
  #184
dick_landy's Avatar
There is a new tenant moving into chateau five point three. His name is cam.
Old Mar 27, 2013 | 07:36 PM
  #185
dick_landy's Avatar
Cam and springs arrived today, DOD delete should be here soon as well and then the fun begins!
Old Mar 28, 2013 | 10:20 PM
  #186
Roided's Avatar
very interested to see the results from this cam
Old Apr 28, 2013 | 11:22 PM
  #187
dick_landy's Avatar
Took the truck out for the first time this year. Meth system works flawless, blower stays physically cooler and feels stronger in the top end. Next weekend I'm starting the cam install then dyno tuning for all the changes. Track opens in 3 1/2 weeks and I'm hoping to get into the 11.90's.
Old May 4, 2013 | 12:15 PM
  #188
dick_landy's Avatar
Originally Posted by iamkeniff
LS9 Camshaft 12638427
Lifters 12499225
Valve springs 12499224
Front Cover 12600326you do not need this
Cam sensor 12591720 you do not need this
Cam sensor extension harness 12627501 you do not need this
Front cover gasket 12633904
Front crank seal 12585673
Push Rod Guide 12595365 x4
3 bolt 4x cam sprocket 12586481
Cam sprocket bolts 12556127 get arp bolts imho
Valley cover 12598832
Ls2 dampener 12588670
Get arp head bolts/studs depending boost.
You need a crank bolt (arp is what i run)
Arp cam plate bolts too. I dont know the part numbers on my thread but buy what i listed. Its cheaper on sdparts.com imho
Turns out I do need this. My truck is VVT. Luckily my buddy has one on a motor sitting at his shop I can pirate for now to get this done.
Old May 5, 2013 | 04:14 AM
  #189
rjwz28's Avatar
Man Motor club
Any more info regarding a larger blower inlet?
Old May 5, 2013 | 12:44 PM
  #190
dick_landy's Avatar
There is nothing that will work so at some point I will modify the one I have, for the moment I'm going to get everything together and run it at the track when it opens in 2 weeks. Now that I've had it off and could take a good look at it I have a good idea of what needs to be done. The cam and DOD delete will be finished today.
