Sneaky Silverado
#181
I haven't got a clue as to what it's worth, I'm thinking 5-600 bucks. I'm thinking the inlet from a whipple would be the easiest, if I don't hear back by Wednesday I'll give both a call.
#183
Lysholm wants $245 plus shipping for the Camaro inlet and Whipple wants $400 plus shipping for their truck inlet. Upon some research, neither are a bolt on deal. The bypass valve bung on both inlets would have to be reworked. I'm going to look into reworking my inlet by cutting it and adding material to open it up and put a new flange on it. Guys with Whippled Cobra's have done similar rework so it is possible.
#187
Took the truck out for the first time this year. Meth system works flawless, blower stays physically cooler and feels stronger in the top end. Next weekend I'm starting the cam install then dyno tuning for all the changes. Track opens in 3 1/2 weeks and I'm hoping to get into the 11.90's.
#188
LS9 Camshaft 12638427
Lifters 12499225
Valve springs 12499224
Front Cover 12600326you do not need this
Cam sensor 12591720 you do not need this
Cam sensor extension harness 12627501 you do not need this
Front cover gasket 12633904
Front crank seal 12585673
Push Rod Guide 12595365 x4
3 bolt 4x cam sprocket 12586481
Cam sprocket bolts 12556127 get arp bolts imho
Valley cover 12598832
Ls2 dampener 12588670
Get arp head bolts/studs depending boost.
You need a crank bolt (arp is what i run)
Arp cam plate bolts too. I dont know the part numbers on my thread but buy what i listed. Its cheaper on sdparts.com imho
Lifters 12499225
#190
There is nothing that will work so at some point I will modify the one I have, for the moment I'm going to get everything together and run it at the track when it opens in 2 weeks. Now that I've had it off and could take a good look at it I have a good idea of what needs to be done. The cam and DOD delete will be finished today.
