Pros and Cons of Turbo Kits?
Im seriously looking at the budget Trick Performance kit that they have up for $1800. What are the pros and cons you guys have found with any and all turbo kits for our trucks? Im not really talking about quality, because im sure that will be there coming from Trick and the good things Ive read so far. Just really wanting to know about the ease of installs, tuning these trucks being turbo'd, ect....
transmissions dont last
other than that they are pretty good maintence wise. you cant be a 87yr old man and not service the truck. it needs fresh oil, filter cleaning, good fuel (93 octane) and a damn good tune.
also you are looking at a 76mm vs a 70mm
the 70mm "being a smaller turbo" will spool faster, and get him into the power band faster. the thing with the smaller turbo it can only go so fast before it is maxed out. thats why people buy the 72mm+ because they plan on a forged motor, and 13+psi. i honestly dont think the truck will see past 7-10psi max.
gotta think of a turbo as a cam...where do you want your power band? small cam = more torque in the lower RPMs, bigger cam = more torque in a higher RPM that requires more converter to make the truck move good.
the 70mm "being a smaller turbo" will spool faster, and get him into the power band faster. the thing with the smaller turbo it can only go so fast before it is maxed out. thats why people buy the 72mm+ because they plan on a forged motor, and 13+psi. i honestly dont think the truck will see past 7-10psi max.gotta think of a turbo as a cam...where do you want your power band? small cam = more torque in the lower RPMs, bigger cam = more torque in a higher RPM that requires more converter to make the truck move good.
Choda
Jan 22, 2026 02:03 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
