Pinon Angle Question
Old 11-22-2014, 04:47 PM
fillpot's Avatar
Default Pinon Angle Question
O
Ok guys 13 gmc ext cab lowered 7 and 4 with mcgaugheys kit, got some vibriation so checked the pinon angle and I'm at -1.5 haven't checked the trans, is this in the ball park? THANKS!
Old 11-22-2014, 09:33 PM
oakley6575's Avatar
You need to measure the the trans output angle and compare them to the pinion angle. Should pretty much be equal and opposite but the u joints need 1/2 a degree differential to oscillate and lube themselves properly.
Old 11-23-2014, 06:33 PM
fillpot's Avatar
Thanks bro, yea I'm going to get it up on some wooden boxes my buddy has tomorrow, he uses the boxes to scale cars, then I can check it all out good, I hope they'll hold the bitch up lol. THANKS!
Old 11-25-2014, 05:12 PM
fillpot's Avatar
Guys just done some checking and it looks like I'm 10 degrees up on the pumpkin and 0 on the drive shaft with the suspension loaded, what should it be. THANKS!
Old 11-25-2014, 05:47 PM
Jeebalow's Avatar
The trans and pinion should be parallel. So if your trans is 3 degrees down you would need the pinion to be 3 degrees up and then just make sure you have at least between 0.5 and 1 degree at each u joint to ensure they don't destroy themselves.
Edit-this is assuming a single piece drive shaft. 2 piece is a little different . Here's a manual from spicer/dana
File Type: pdf
Old 11-25-2014, 08:16 PM
fillpot's Avatar
Thanks bro good info!
Old 11-29-2014, 04:12 PM
iamkeniff's Avatar
where are you getting your angle at on the rear end? you are suppose to check it at the pinion yoke vs driveshaft not the actual rear end.
Old 12-04-2014, 09:07 AM
fillpot's Avatar
Yea that's where I'm getting it at, the trans spacer didn't help **** time to start shimming. THANKS!
Old 12-04-2014, 09:31 AM
iamkeniff's Avatar
Pull the trans spacer so you wont have to run as much shim imho.
Normally a MCG flip kit needs 4* shims.
Make sure you get the shim kit that has the new longer bolt. Stay away from aluminum if you plan on making power. Steel is where its at
Unless you want to get new leaf perches welded on like i did
Old 12-04-2014, 10:46 AM
fillpot's Avatar
That's where I was going to start, man the pinon seems real high though? THANKS!
Quick Reply: Pinon Angle Question
