Pinon Angle Question
Old 12-15-2014, 02:10 PM
  #31
fillpot's Avatar
Thanks man, one more question, the shims have a round hole and then a slot, I'm thinking the slot goes over the pen. THANKS!
Old 12-15-2014, 02:51 PM
  #32
iamkeniff's Avatar
The round hole is for the leaf pack bolt to go through it so you clamp it to the leaf pack. A longer bolt is required for that. As for the slots thats so you can use the shims without bolting them down to line up the rear end.
Old 12-15-2014, 03:46 PM
  #33
fillpot's Avatar
Gotcha I was over thinking it lol, just bolted everything back up, the rearend seemed a little out of square last night after a couple of passes at the track, looked to be a 1/8 to 3/16s out, took the leaf pack bolt and welded a 1/4 nut on top of it to help keep things lined up, so it all looks good now going to take it at to my buddies and check the pinon angle, I'll get back I'll post up what we find. THANKS!
Old 12-16-2014, 12:47 PM
  #34
fillpot's Avatar
Guys this is what I'm thinking, didn't get to check the pinon angle last night should be able to today, but the vibriation is a lot better, looks like the rearend slipped and that's my fault for not tightening up the u-bolts the other night and some m&hs and the track, any way the gears basically sound like pure ****, so I'm going to find some GM gears and a new installer some where in the southeast lol, I'm down around Mobile Al and it seems hard to find someone good at gear installs,also it may be hard to find a gm gear for this 13 model truck, I believe we were going to gothat way before but had a hard time finding a set, especially at my small town dealer, any suggestions. THANKS!
Old 12-17-2014, 11:56 AM
  #35
fillpot's Avatar
Also guys does anyone no of a good reliable shop in the South or even in the South East that could check this rear end out. THANKS!
Old 12-18-2014, 04:07 PM
  #36
iamkeniff's Avatar
https://www.performancetrucks.net/fo...ll-kit-530654/
I dont but if i was you id start looking for someone that does it performance wise vs just a mom and pop repair shop UNLESS they are good at what they do
Old 12-18-2014, 04:39 PM
  #37
fillpot's Avatar
Man that's what I want to do, I really don't want to go back to 3.42s, I'm in Atmore Al, about 50 miles from Moile Al, and Pensacola Fla, ideas of any shops in my area, and I don't mind traveling any body around you area that you recommend. THANS!
Old 12-18-2014, 08:17 PM
  #38
iamkeniff's Avatar
maybe post up in the "region" section for a trusted shop someone else may have used?
Old 12-18-2014, 09:15 PM
  #39
iamkeniff's Avatar
Southern - PerformanceTrucks.net Forums
here you go buddy, hope you can find what you need here if not then continue to look for performance shops in/around your area
andrewlong
11-09-2016 09:38 AM
andrewlong
09-08-2015 10:25 PM
Forcefed81
09-08-2015 10:02 PM
2004gibbstruck
09-07-2015 06:05 PM
iregret
09-07-2015 01:20 PM
Quick Reply: Pinon Angle Question
