Pinon Angle Question
The trans and pinion should be parallel. So if your trans is 3 degrees down you would need the pinion to be 3 degrees up and then just make sure you have at least between 0.5 and 1 degree at each u joint to ensure they don't destroy themselves.
Edit-this is assuming a single piece drive shaft. 2 piece is a little different . Here's a manual from spicer/dana
Pull the trans spacer so you wont have to run as much shim imho.
Normally a MCG flip kit needs 4* shims.
Make sure you get the shim kit that has the new longer bolt. Stay away from aluminum if you plan on making power. Steel is where its at
Unless you want to get new leaf perches welded on like i did
