Ordered Whipple
Old Sep 7, 2011 | 11:49 AM
  #161
Boober's Avatar
Originally Posted by tiffo60
I have my set to shift @ 6k in first 4 gears
As far as the TPS goes my WOT shows 83% in HP Tuners, this is normal and there is a thread about it somewhere but basicly you have 100% throttle even though HP Tuners is logging 83-84%
Found the thread
https://www.performancetrucks.net/fo...estion-434915/
Yeah, I found it in HP Tuners forum. I need to look at ETC % instead.
Old Sep 7, 2011 | 01:35 PM
  #162
rjwz28's Avatar
Man Motor club
Mine shifts at 6000 also, unless I shift manually, in which case I hit the limited at 6400. Did once, won't be doing again lol.
Old Sep 7, 2011 | 02:44 PM
  #163
BrutalSierra's Avatar
I bet with some headers ORY this truck would pick up crazy HP! And some bigger gears would really help overcome the big wheels.
Old Sep 13, 2011 | 05:26 PM
  #164
Boober's Avatar
Yet another update: I finally got around to installing my boost gauge yesterday. Also, I am getting an O2 sensor bung welded in tomorrow so I can finish installing my wideband. I am waiting on HP Tuners to send my new pro interface box so that I can track my air/fuel ratio in the program.
I also finally found out what my peak boost is. Pretty much as suspected, it's 6.5 psi. I talked to Jeff and Mike at Whipple and it was agreed that I should step down to a 3.375" pulley. That should add about 2 psi and take me to 8.5 psi. I also asked about any tuning changes needed, and Mike said that no changes would be needed. I'm certainly going to keep a close eye on my injectors after installing the new pulley. Theoretically, this change should take me to where the system is supposed to be in the first place (8-10 psi).
With just a pulley change, and some small tweaks that I have already made (removed speed limiter, changed shift points for 1-2,2-3,3-4) I should expect a nice improvement at the track. We shall see.
Update 9/20/11: just a quick update (to myself I guess ), I installed my new pulleyt today. I have not had much chance to do a full test but it's a very nice and noticeable improvement. I'm hitting right around 9 psi at WOT so I picked up a little more than 2 psi. The real difference is up top as would be expected. Air/fuel is still around 12 at WOT. I don't have my interface back to log any runs. I was hoping to get to the track this Friday but since I won't have much time to dial in my transmission changes, it might have to wait until next Friday. My but dyno says low 13's at 101-103. If I can dial in the shift points and get some good launches, I'm thinking high 12's are definitely possible.
Old Sep 20, 2011 | 10:21 PM
  #165
bdubb's Avatar
Good news! I'm looking forward to hearing about your track times when you make it out.
Old Sep 21, 2011 | 12:24 PM
  #166
fortplainman's Avatar
sounds good man, let us know when you run it or end up doing any fine tuning.
Old Sep 21, 2011 | 02:29 PM
  #167
03sierraslt's Avatar
Bring that thing out to the flashlight drags this Fri. We will have some fun with cars. Ill run ya.
Old Sep 21, 2011 | 03:25 PM
  #168
Looking forward to an update! Please add some more bolt on's lol
Old Sep 21, 2011 | 08:08 PM
  #169
Boober's Avatar
It's at Beaverun on Friday right? I might try to make it. If I don't have a chance to work on my tranny tuning, I will probably come.
Old Sep 21, 2011 | 08:26 PM
  #170
Yep thats where it is. I went last week and worked on my meth tune there. Its really the only place I can get on mine hard around here anymore.
