never satisfied, looking for deeper 12s
Old Nov 17, 2010 | 11:00 PM
  #61
iamkeniff's Avatar
as you can tell they dont use the same transmission cooler lines like the 60/65/75/80e
im going to try and find a stock cooler line set up and go from there.
http://bowlertransmissions.com/item-details/?iid=687
i can buy this block with -6AN fittings and run my own lines, but then id have to figure out what size fittings id need at the radiator.
the 6L80e's are 3/8" whats the 60e size? 5/16"?
Old Nov 17, 2010 | 11:01 PM
  #62
iamkeniff's Avatar
Originally Posted by Bumpers
What you were talking about with gearing isn't the 6th gear really close to the 4th of a 60?
the 1st gear on the 6spd with 3:42s is the same as my 60e with 4:10s. no im running 4:10s so what would the 1st gear be with the 6spd?
Old Nov 17, 2010 | 11:09 PM
  #63
Bumpers's Avatar
Guessing it would be comparable to somehwere between 4.56 and 4.88s but look at skeets times and 60ft (I know your trucks a lot heavier and won't launch like a 4linked 3500lb truck) but I was just wondering about 4thgear compared to the 6th gear of the two trans
Old Nov 17, 2010 | 11:12 PM
  #64
iamkeniff's Avatar
i dont have a clue, did you look up the ratios i never did.
Old Nov 17, 2010 | 11:21 PM
  #65
Bumpers's Avatar
I haven't but I read somewhere that they were almost the same.. I would wait till you get the trans in run the 4.10s and see what she does
Old Nov 17, 2010 | 11:49 PM
  #66
iamkeniff's Avatar
im not swapping gears unless i have to.
Old Nov 18, 2010 | 07:02 AM
  #67
CI DENALI's Avatar
Originally Posted by supercharged680
u guys are lucky ur 2wd.. much lighter than my AWD.. launching is easier.. i agree but the 2wd is faster as soon as u get some grip , is there anyway to convert AWD to 2wd? and back again
Nope. The BW transfer case in our trucks is actually an open center differential, so the truck won't move if you disconnect the front driveshaft.
Old Nov 18, 2010 | 07:12 AM
  #68
CI DENALI's Avatar
Gear ratios on the 6L80E:
1st- 4.027:1
2nd- 2.364:1
3rd- 1.532:1
4th- 1.152:1
5th- 0.852:1
6th- 0.667:1
Reverse -3.064:1
Note that, unlike any other transmission GM has produced, there is no 1:1 gear ratio :-
4th is an underdrive and 5th is an overdrive ratio.
Old Nov 18, 2010 | 07:58 AM
  #69
Bumpers's Avatar
Now what's the gear ratios on a 60e?
Old Nov 18, 2010 | 09:04 AM
  #70
iamkeniff's Avatar
they're CRAP
tomorrow i start to pull the tranny set up out i cant wait!
